Guest aksu Posted October 9, 2007 Share Posted October 9, 2007 Hi can someone help i have a tt supra gz modell aerotop 1996 i had an accident and now my active spoiler does not work motor is ok but there is a flashing light in the dash bord which says spoiler problem contack toyota dealer. But they dont even know .and the car is in cyprus and there is no toyota dealer there ,can some one please advise what it could be. I cant get any power from the switch were you can bring the spoirler down manuly to the spoirler motor all fusses are ok or can someone advise were there could be another fuse or relay for the spoirler can it be what they say the brain of the car everything is now new but stil not working.> thank you> Aksu Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 9, 2007 Share Posted October 9, 2007 Firstly, you can only bring the spoiler down manually if the ignition is set to ACC or something.. engine has to be off. Secondly, my Active Spoiler did the same as yours after an accident (in my last car, the UK one).. the light on the dash would blink. All I had to do to fix it was to unbolt the brackets a bit and straighten them out. The system seems to be sensitive to resistance. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted October 9, 2007 Share Posted October 9, 2007 LOL! Same answer as the last 2 times you asked! Quote Link to comment Share on other sites More sharing options...
colsoop Posted October 9, 2007 Share Posted October 9, 2007 Firstly, you can only bring the spoiler down manually if the ignition is set to ACC or something.. engine has to be off. Secondly, my Active Spoiler did the same as yours after an accident (in my last car, the UK one).. the light on the dash would blink. All I had to do to fix it was to unbolt the brackets a bit and straighten them out. The system seems to be sensitive to resistance. I said this last time to the guy he says it is all straight and true Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 9, 2007 Share Posted October 9, 2007 Ah yes, so I see Well, to be fair, my actual spoiler mechanism wasn't bent. Mine was simply bits of mud/grass, and the very thin aluminium plates needed a tidy/straighten-up. The big solid bits were perfectly straight. It really does seem to be a sensitive mechanism.. like I say I didn't have any bends in the solid parts. I only skated up/along a hilly mound -no front end damage. Quote Link to comment Share on other sites More sharing options...
Guest aksu Posted October 9, 2007 Share Posted October 9, 2007 What i am trying to say is everything now is new but i cant get any power from the switch to the machanism motor so i cant even operate it manualyy Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 9, 2007 Share Posted October 9, 2007 What i am trying to say is everything now is new but i cant get any power from the switch to the machanism motor so i cant even operate it manualyy This could be by design. Are you sure there is supposed to be power at the switch at all times? Can you confirm that you do understand the engine off/ACC ignition requirement? Quote Link to comment Share on other sites More sharing options...
Guest aksu Posted October 9, 2007 Share Posted October 9, 2007 Yes i do i know nearly everything about the supra but this is something new to me [ i dont know if power should be there all the time] but before the key in acc and you could opperate the machanism but now no and i know if you take the machanism out and stick a 12 w power it works Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 9, 2007 Share Posted October 9, 2007 Can you take the mechanism out and try the switches with it hanging off the car/sat on the floor? Do the cables reach far enough? How bad was the accident (got pics? ). Could it have severed some cables around the spoiler area? Quote Link to comment Share on other sites More sharing options...
