Na 1st decat fitting problem
berg
Hi guys trying to fit my 2 decats today
Not sure how the first decat is going to seal at the top 2 flanges where it meets the manifold
Standard is like this with a ring gasket on each flange
New ones are like this with no gaskets
And the second decat looks an inch bigger than the cat when next to each other
Any ideas??
Edited by berg (see edit history)
Ok cheers Paul ill get hold of some. Managed to get 2 gaskets anyway so i might try them and check the seal.
Found out the rest of my exhaust has been badly modified using a standard centre pipe attatched to the big backbox using the worst welding ive ever seen. Come arcross 5 or 6 holes so far
Whole exhaust had to come off in one and both cats had to have the bolts grinded off to seperate.
Just gonna buy a whole new aftermarket cat back now aswell whole new system then
