Geo Posted June 18, 2012 Share Posted June 18, 2012 (edited) Speaking with Ross yesterday at the Cars and Rides meet in Glasgow and he was asking about Servicing, and asked if i can help him do his on his car before pod? Im checking dates as im on standby alot just now, due to boss being off alot. I came up with this little list, if i've missed anything can you let me know? FAO ROSS Read and get to know the Locations of everything were going to change Oil Change http://www.jack-frost.co.uk/toyota_supra_oil_change.html Spark Plug change http://www.mkivsupra.net/vbb/showthread.php?4262-S-Plugs/page3 post 37 http://mkiv.com/techarticles/spark_plugs/na/ FUEL filter >> http://www.mkivsupra.net/vbb/attachment.php?attachmentid=10303&d=1098462712 3) Get the car up in the air, preferrably on a ramp, failing that get the front on ramps/axle stands. 4) Remove the 2 EFI fuses from the fuse box under the bonnet, crank the engine over a few times to depressurise the system. 5) IMPORTANT: using a spanner on the flats on the filter and a (pipe) spanner on the flare nuts on the pipe, just loosen the pipe connections either end of the filter. You will get petrol coming out, but depending on the level of the tank and the angle of the car, hopefully not too much. Be prepared for the worse, with lots of absorbant rags. 6) Remove the 2 filter retaining bolts 7) Remove the filter pipes using 2 spanners, be prepared for (lots of) petrol spillage, but dont panic 8) Fit the pipes to the new filter, don't panic and cross thread them, and don't tighten them yet, so that you can position the filter 9) Replace the 2 filter retaining bolts, remembering to fit the earth strap 10)Tighten the filter pipes using both spanners 11)Replace the 2 EFI fuses 12)Start the car and check for leaks 13)lower car from jacks, drive off ramp etc. 14)congratulate yourself on another job well done Oxygen Sensors http://www.mkivsupra.net/vbb/showthread.php?152779-How-to-Clean-O2-sensors-in-NA&highlight=sensors%20clean Coolant change - http://www.mkiv.com/techarticles/coolant_flush/index.html Parts Required - Oil 6ltrs £54.90(5ltrs) £14.99(1ltr) Pro S Opie Oils Oil Filter £ 5.40 Opie Oils £Toyota trade 8.89 Sump washer £ 1.19 6 Spark Plugs £ 53.65 http://www.opieoils.co.uk/p-63543-ngk-spark-plug-bkr5eix-11-opie-ref-5464.aspx Fuel Filter £ 24.46 Opie OILS £34.98 Coolant 5ltrs £ motul 23.76 Opie Oils £ 19.26 2x Oxygen Sensors £ - 273.88(will replace on next service) Toyota Price's(trade @ Linwood Glasgow) Oil Filter £ 8.99 Sump Washer £ 1.19 Fuel Filter £ 34.98 Red Coolant 5ltrs £ 19.26 2x Oxygen Sensors £ 273.88(Will replace on next service) Edited June 20, 2012 by Geo (see edit history) Quote Link to comment Share on other sites More sharing options...
SPG Posted June 18, 2012 Share Posted June 18, 2012 How about the Diff Oil Quote Link to comment Share on other sites More sharing options...
mellonman Posted June 18, 2012 Share Posted June 18, 2012 how often do you change the fuel filter and do you just get a motor factors one? Quote Link to comment Share on other sites More sharing options...
Geo Posted June 18, 2012 Author Share Posted June 18, 2012 How about the Diff Oil Yup, i'd rather do that on a ramp though. how often do you change the fuel filter and do you just get a motor factors one? The car has 120,000 on the Odo, and cant be sure if its ever been changed? So id do it every 50,000 and use Stock Part, pennies from Toyota. Quote Link to comment Share on other sites More sharing options...
mellonman Posted June 18, 2012 Share Posted June 18, 2012 fuel filter price toyota £36.96 +vat euro car parts £11.25 +vat ebay £9 cheapest i could find maybe cheap from toyota but its a big differance Quote Link to comment Share on other sites More sharing options...
Tyson Posted June 18, 2012 Share Posted June 18, 2012 fuel filter price toyota £36.96 +vat euro car parts £11.25 +vat ebay £9 cheapest i could find maybe cheap from toyota but its a big differance I payed 26.83 inc VAT from my Toyota Quote Link to comment Share on other sites More sharing options...
mellonman Posted June 18, 2012 Share Posted June 18, 2012 dodgy gits, saying that she was trying to tell me it didnt even have one at first lol might be because you have a uk spec i know there the same but it does make a differance Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted June 18, 2012 Share Posted June 18, 2012 Some of the fuel filters can be a right sod to get off so it may be wise as suggested in another thread to have a bit of fuel line to hand just incase the worst happens. Quote Link to comment Share on other sites More sharing options...
Tyson Posted June 18, 2012 Share Posted June 18, 2012 dodgy gits, saying that she was trying to tell me it didnt even have one at first lol might be because you have a uk spec i know there the same but it does make a differance Yeah the guy did ask me wether mine was an import as they are harder to get parts for ..... I did try to explain to him that virtually all the parts are identical but he was having non of it Quote Link to comment Share on other sites More sharing options...
SPG Posted June 18, 2012 Share Posted June 18, 2012 How about the Diff Oil Yup, i'd rather do that on a ramp though. im getting visions of "Twins" (the movie with Arnold), im sure Ross can trust you holding the back end off the ground while he does the necessary fluid extraction and insertion Quote Link to comment Share on other sites More sharing options...
Ross C Posted June 18, 2012 Share Posted June 18, 2012 Thanks for this Geo. Will have a thourogh read through these over the next few days and dont go out of your way to do it before Pod Quote Link to comment Share on other sites More sharing options...
Geo Posted June 18, 2012 Author Share Posted June 18, 2012 Thanks for this Geo. Will have a thourogh read through these over the next few days and dont go out of your way to do it before Pod Got IanW helping bud, im sure we can get through most of that list, with the plugs being the longest to change i reckon. What you wana do about the parts? Quote Link to comment Share on other sites More sharing options...
Ross C Posted June 18, 2012 Share Posted June 18, 2012 (edited) Got IanW helping bud, im sure we can get through most of that list, with the plugs being the longest to change i reckon. What you wana do about the parts? I'd prefer you total it, i'll paypal you the money and then you buy them but thats just me just not wanting to make a mess of things ordering the wrong thing. Its totally up to you as I know that it would put alot of the onus on you which is unfair because its my car. Edit: If you can supply me with the exact links to all the exact parts to buy via this or facebook then i can do it easily enough myself. At the end of the day you are doing me a favour and I dont want to push my luck Edited June 18, 2012 by Ross C (see edit history) Quote Link to comment Share on other sites More sharing options...
mellonman Posted June 18, 2012 Share Posted June 18, 2012 just got one from euro car parts Total £13.50 fitted is in about 30min all went will with geos guide new one i could blow through very easily but the old one that had done about 60k was abit harder to blow through Quote Link to comment Share on other sites More sharing options...
BK1 Posted June 18, 2012 Share Posted June 18, 2012 Speaking with Ross yesterday at the Cars and Rides meet in Glasgow and he was asking about Servicing, and asked if i can help him do his on his car before pod? Im checking dates as im on standby alot just now, due to boss being off alot. I came up with this little list, if i've missed anything can you let me know? FAO ROSS Read and get to know the Locations of everything were going to change Oil Change http://www.jack-frost.co.uk/toyota_supra_oil_change.html Spark Plug change http://mkiv.com/techarticles/spark_plugs/na/ FUEL filter >> http://www.mkivsupra.net/vbb/attachment.php?attachmentid=10303&d=1098462712 3) Get the car up in the air, preferrably on a ramp, failing that get the front on ramps/axle stands. 4) Remove the 2 EFI fuses from the fuse box under the bonnet, crank the engine over a few times to depressurise the system. 5) IMPORTANT: using a spanner on the flats on the filter and a (pipe) spanner on the flare nuts on the pipe, just loosen the pipe connections either end of the filter. You will get petrol coming out, but depending on the level of the tank and the angle of the car, hopefully not too much. Be prepared for the worse, with lots of absorbant rags. 6) Remove the 2 filter retaining bolts 7) Remove the filter pipes using 2 spanners, be prepared for (lots of) petrol spillage, but dont panic 8) Fit the pipes to the new filter, don't panic and cross thread them, and don't tighten them yet, so that you can position the filter 9) Replace the 2 filter retaining bolts, remembering to fit the earth strap 10)Tighten the filter pipes using both spanners 11)Replace the 2 EFI fuses 12)Start the car and check for leaks 13)lower car from jacks, drive off ramp etc. 14)congratulate yourself on another job well done Oxygen Sensors http://www.mkivsupra.net/vbb/showthread.php?152779-How-to-Clean-O2-sensors-in-NA&highlight=sensors%20clean Coolant change - http://www.mkiv.com/techarticles/coolant_flush/index.html Parts Required - Oil 6ltrs Oil Filter Sump washer 6 Spark Plugs Fuel Filter Coolant 5ltrs 2x Oxygen Sensors Nice one mate, very handy Quote Link to comment Share on other sites More sharing options...
Geo Posted June 19, 2012 Author Share Posted June 19, 2012 First post updated with prices. Quote Link to comment Share on other sites More sharing options...
Ross C Posted June 19, 2012 Share Posted June 19, 2012 First post updated with prices. Looking at those prices, the only thing I cannot do is the new Oxygen sensors. Cannot justify that sort of money atm with pod comming up but im game for all the rest to get the car running sweeter Quote Link to comment Share on other sites More sharing options...
mellonman Posted June 19, 2012 Share Posted June 19, 2012 you can get them alot cheap else where if you search and know what you are looking for Quote Link to comment Share on other sites More sharing options...
Ross C Posted June 19, 2012 Share Posted June 19, 2012 you can get them alot cheap else where if you search and know what you are looking for I clearly havent got a clue Quote Link to comment Share on other sites More sharing options...
Geo Posted June 19, 2012 Author Share Posted June 19, 2012 I'll see if i cant find them cheaper else where, mind that was the toyota price. Quote Link to comment Share on other sites More sharing options...
mellonman Posted June 19, 2012 Share Posted June 19, 2012 lol find out what type of o2 sensor they are IE 1 wire 2 wire 3 wire 4 wire fitment flanged and not flanged this might help http://mkivsupra.net/vbb/showthread.php?262641-n-a-lambda-in-tt the links seem to have changed a little but the site should still be okay just make sure you check what you have, denso is toyotas supplier Quote Link to comment Share on other sites More sharing options...
SPG Posted June 19, 2012 Share Posted June 19, 2012 Im sure http://www.sparkplugs.co.uk carry the Denso O2 Sensors for a decent saving compared to Mr T Quote Link to comment Share on other sites More sharing options...
Geo Posted June 19, 2012 Author Share Posted June 19, 2012 There 1 wire. Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted June 19, 2012 Share Posted June 19, 2012 Rock auto is about £80 for 2 O2 sensors including shipping from the US iirc. Quote Link to comment Share on other sites More sharing options...
Geo Posted June 19, 2012 Author Share Posted June 19, 2012 Can someone confirm these are the right ones? part number are slightly different and it only lists it as a http://www.sparkplugs.co.uk/pages/pricing/ccp/Denso-Lambda-Sensors-ccp.asp Make TOYOTA Model Supra Engine Size 3L Production (Month/Year) 01/1986 -> 07/1988 Engine Code 7MGE Engine Power (KW) 150 Important info N/A Quote Link to comment Share on other sites More sharing options...
