SamuraiFlash Posted July 16, 2010 Share Posted July 16, 2010 The front crank seal on my N/A Supra needs replacing and I want to know how it should be fitted? Pushed all the way in or sitting flush? where will I be able to buy a front crank seal kit from? My supra also had a leak/blow where the manifold meets the cat, replacing the gasket that goes between the manifold and cat should sort this issue out but not sure where to buy one from thanks in advance. Link to comment Share on other sites More sharing options...
nevins Posted July 16, 2010 Share Posted July 16, 2010 Toyota is your best bet . Link to comment Share on other sites More sharing options...
Nic Posted July 16, 2010 Share Posted July 16, 2010 Toyota for seal and gasket. Recent thread HERE about oil seal. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted July 17, 2010 Author Share Posted July 17, 2010 Thanks Nic that's the thread I was looking for do you guys know the part number fir the front crank seal and gasket for an NA, just to save the hassle when I go over to see my local Toyota dealer. Link to comment Share on other sites More sharing options...
