Help! Overboost!!!
BigMoistyturbo
Originally posted by BigMoistyturbo
I'm worried because my j-spec is boosting to 1.3/1.4 bar. All it has it apexi air filter,FCD,Cat back nur spec,HKS SSQ.
What could be causing this?
Before I reach the top of the rev range I'm at 1.4 bar and the car struggles to make the top of the revs!
I still have both my cats in.
Get a restrictor ring off CW!
Check your plugs!
:thumbs:
Guest Terry S
Moisty, you want to bung in a colder plug like a 7 with more than stock boost. If you can't stretch to Denso IK's then get a set of BKR7ES from Halfrauds.
Originally posted by HISUPE
Shouldn't overboost with the stock cats in though should it? Only when decatted...................
Well, by that I mean to the extent you are seeing, as its possible with cats and an aftermarket cat back system to just creep above the stock fuel/boost cut in certain circumstances. Not as high as you've been boosting though.........
