Error codes again- no idea
jamesmark
14 - No Ignition Feedback signal to ECU - Dodgy coilpack clips (Change even if they look OK), Coil packs, loose Loom plugs on ECU or dodgy Igniter pack. Check sparkplugs too
25 - Air Fuel Ratio lean malfunction - Problem with Oxygen sensor, Oxygen sensor circuitry, Ignition system or ECU
Both problems seem related
http://www.mkivsupra.net/vbb/showthread.php?t=35920
Ro
