BASHTHEBISHOP Posted November 1, 2006 Share Posted November 1, 2006 Got in the car after work today and it started fine but as soon as my foot hit the throttle it was accompanied by a 'whiney' noise. This carried on in tandum with the throttle for the 1st couple of miles and then stopped. I stopped at a shop a few miles later & yet again same thing happened after starting the car and starting to drive. The noise increases in pitch and level the more i apply the throttle. The closest thing i can describe it to is like the power steering whine you hear on some cars when applying heavy steering at slow or stationary speeds.. Any ideas any one? PS - other than the noise car seems fine. Link to comment Share on other sites More sharing options...
RedM Posted November 1, 2006 Share Posted November 1, 2006 I think I get this and only during the winter. Something to do with the BOV but I may be wrong. Once it warms up it all seems fine. Link to comment Share on other sites More sharing options...
Kranz Posted November 1, 2006 Share Posted November 1, 2006 Ancillary belt squeal due to the cold & damp??? Or the idler or tensioner bearing?? Link to comment Share on other sites More sharing options...
Feakins Posted November 1, 2006 Share Posted November 1, 2006 Or possible crank pulley? Mine used to make a small whine but it stopped after 5 seconds. Link to comment Share on other sites More sharing options...
RedM Posted November 1, 2006 Share Posted November 1, 2006 Not so much a squeal more of a low, moaning whistle. Almost like a sound effect from a ghost movie. Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted November 1, 2006 Author Share Posted November 1, 2006 Thanks guys. Is worst case scenario that i might have to replace the crank pulley then? Link to comment Share on other sites More sharing options...
Kranz Posted November 1, 2006 Share Posted November 1, 2006 Try spraying a bit of Wd40 on the belt when its running & making this noise at idle (if it does) to rule out belt problems. Can you record the sound??? Link to comment Share on other sites More sharing options...
RedM Posted November 1, 2006 Share Posted November 1, 2006 Have a look at this thread. http://www.mkivsupra.net/vbb/showthread.php?t=52240&highlight=ghostly Link to comment Share on other sites More sharing options...
Tom Posted November 1, 2006 Share Posted November 1, 2006 Try spraying a bit of Wd40 on the belt when its running & making this noise at idle (if it does) to rule out belt problems. Can you record the sound??? yep that would be my exact advice Link to comment Share on other sites More sharing options...
