Darren Posted September 5, 2006 Share Posted September 5, 2006 Am I right in saying that XS Power and SS Autocrome are not the same company? And that XS Power parts are better quality than SS Autocrome? Its just that SS Autocrome seem to sell/list XS power parts on Ebay? I'm lost now! Anyone confirm? Link to comment Share on other sites More sharing options...
GeordieSteve Posted September 5, 2006 Share Posted September 5, 2006 Same company Link to comment Share on other sites More sharing options...
TubbyTwo Posted September 5, 2006 Share Posted September 5, 2006 yep they are the same company. cant speak for Supra Parts as i still drive an MR2, but a lot of MR2 owners have found that the intercoolers are very good for the price, however its the down pipes and manifolds that are worth steering clear of. One chap on mr2oc fitted an XS power downpipe and it cracked within a week. like i said i cant speak for supra parts but thats pretty much the MR2 community view on things. Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2006 Author Share Posted September 5, 2006 And is this the stuff that Turbofit are successfully using? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 5, 2006 Share Posted September 5, 2006 I have one of their tubular manifolds working for a few months on a Skyline, BUT!!!! I made proper drop link supports for the turbo and wastegate. MUCH cheaper than a "proper" manifold, which is circa 3k, and for a weekend fun car maybe an option? I also have a brand new TO4 flanged one for a 2JZ-GTE engine for sale, cheap Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2006 Author Share Posted September 5, 2006 I have one of their tubular manifolds working for a few months on a Skyline, BUT!!!! I made proper drop link supports for the turbo and wastegate. MUCH cheaper than a "proper" manifold, which is circa 3k, and for a weekend fun car maybe an option? I also have a brand new TO4 flanged one for a 2JZ-GTE engine for sale, cheap So if I understand, you stengthened/braced it to cut down on flexing and cracking? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 5, 2006 Share Posted September 5, 2006 I did zilch to the manifold itself, I suspended the turbo and wastegate on rod ended support rods from a cradle off the cam boxes. It's all well documented, they overcame cracking like this as far back as the 80's F1 turbo era. You can see how they did it at ftp://ftp.chriswilson.tv/F1_turbo Link to comment Share on other sites More sharing options...
supradibbs Posted September 5, 2006 Share Posted September 5, 2006 i ran full xs power setup via the turbo installed by turbofit and had no problems with it at all and the car is still running fine 6 months on Link to comment Share on other sites More sharing options...
Guest dee_rz Posted September 5, 2006 Share Posted September 5, 2006 Cheers for the head up of info on the f1 turbo, i'm using a greddy anti heat coated (2k ) manifold which i've heat wrapped too but it will have a fair size turbo on it, so i'm going to do what you've done to reduce stress on the manifold, how think should the rods be as i can get this from work s/steel is best i guess. Thanks chris Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 5, 2006 Share Posted September 5, 2006 I used decent mild steel, avoid alloy as it expands too much. 3/8 or 10 mm is plenty thik enough. Use cheap phosphor bronze lined rod ends, no need for aerospace stuff! Try and support the turbo and wastegate around their C of G, although you may have to compromise somewhat due to logistics of space, clearance and suitable support points. DON'T make the mistake of hanging off the shell, strut brace or anything that isn't the engine or bellhousing, as the engine is rubber mounted... Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2006 Author Share Posted September 5, 2006 I did zilch to the manifold itself, I suspended the turbo and wastegate on rod ended support rods from a cradle off the cam boxes. It's all well documented, they overcame cracking like this as far back as the 80's F1 turbo era. You can see how they did it at ftp://ftp.chriswilson.tv/F1_turbo The tripod shaped bit in the photos? Grey colour? Link to comment Share on other sites More sharing options...
Guest dee_rz Posted September 5, 2006 Share Posted September 5, 2006 I used decent mild steel, avoid alloy as it expands too much. 3/8 or 10 mm is plenty thik enough. Use cheap phosphor bronze lined rod ends, no need for aerospace stuff! Try and support the turbo and wastegate around their C of G, although you may have to compromise somewhat due to logistics of space, clearance and suitable support points. DON'T make the mistake of hanging off the shell, strut brace or anything that isn't the engine or bellhousing, as the engine is rubber mounted... It's great my turbo (garratt gt4088-special) appears to have a support bracket built onto it and it will be in a perfect position for some 10mm rod to go through, i will be able to get me hands on some too infact we always have it in at work will do exactly what you have done in pic. cheers chris your a legend Link to comment Share on other sites More sharing options...
Guest dee_rz Posted September 5, 2006 Share Posted September 5, 2006 The tripod shaped bit in the photos? Grey colour? yep the tripod bit bud Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2006 Author Share Posted September 5, 2006 yep the tripod bit bud cheers! Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 5, 2006 Share Posted September 5, 2006 You need to look at relative heights, as some of the turbo is no doubt ABOVE the cam covers. In case of real difficulty you can support from below with a frame in compression instead of tension. Link to comment Share on other sites More sharing options...
Guest dee_rz Posted September 5, 2006 Share Posted September 5, 2006 I see what your saying, i'll see when i start putting it all on friday and saturday cheers again Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2006 Author Share Posted September 5, 2006 i ran full xs power setup via the turbo installed by turbofit and had no problems with it at all and the car is still running fine 6 months on Did you run their turbo? Sorry cant remember.. Link to comment Share on other sites More sharing options...
GeordieSteve Posted September 5, 2006 Share Posted September 5, 2006 Did you run their turbo? Sorry cant remember.. Nope he run a Garrett turbo Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2006 Author Share Posted September 5, 2006 Nope he run a Garrett turbo Thats interesting my mates going to use one of these manifolds on this skyline then also fit a Garrett. Was just looking on Ebay £599 for supra turbo kit inc intercooler! Incredible... Link to comment Share on other sites More sharing options...
Lebsteif Posted September 5, 2006 Share Posted September 5, 2006 link? Link to comment Share on other sites More sharing options...
toyotatom Posted September 5, 2006 Share Posted September 5, 2006 Am I right in saying that XS Power and SS Autocrome are not the same company? And that XS Power parts are better quality than SS Autocrome? Its just that SS Autocrome seem to sell/list XS power parts on Ebay? I'm lost now! Anyone confirm? http://www.xs-power.co.uk/ Never answers the phone. http://www.ssautochrome.com/ Both use all the same bits. I've got a link to forum discussing these kits and the companies that make them, and it echoes Chris's points and beyond. Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2006 Author Share Posted September 5, 2006 http://www.xs-power.co.uk/ Never answers the phone. http://www.ssautochrome.com/ Both use all the same bits. I've got a link to forum discussing these kits and the companies that make them, and it echoes Chris's points and beyond. Thought Chris said he had used one now and it was ok with a little help? Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 5, 2006 Share Posted September 5, 2006 Darren, would you share the link, i am curious as to peoples general experiences with these. Link to comment Share on other sites More sharing options...
Darren Posted September 5, 2006 Author Share Posted September 5, 2006 Darren, would you share the link, i am curious as to peoples general experiences with these. Think Toyotatom has the link. Hopefully he will be along in a minute Link to comment Share on other sites More sharing options...
toyotatom Posted September 5, 2006 Share Posted September 5, 2006 Sorry, been reading about PS3s in Off Topic. I'll pm you the link Chris, as some might think Im trying to pick a fight again. Link to comment Share on other sites More sharing options...
