NA-T update
Daston
Hi guys
Just thought I would share with you some photos of my ever increasing parts.
Heres the stack
Turbo Manifold (just came today)
Intake
Down Pipe
Filters
BOV
T61 Turbo
Not sure what this is it came with the manifold is this used if the turbo has an internal Waste Gate?
Should have £1900 coming to me so going to get the rest then and get someone else to fit it all to save me the agro
Guest ahmedjbh
please keep us up to date with how it goes, im interested in this, i found this website, some fairly useful info on there, check it out, but as you are doing it piece by peice, im sure you know what you are doing.
good luck.
http://www.clubna-t.com/
Guest HarrisM
Looks good, might go down this road as am bored of the same old NA power..
i take it some sort of engine/fuel management will have to be put in place?
Looking good matey, you wont regret it. Other than that little lot theres also the safc2 to control the air/fuel and i went for the avcr boost controller.
As Jamie says, it does go well :)
And as for reliability ive had it back now around 2 months with no troubles and pulls fine everytime. Plus i have a years guarantee with it all if anything were to happen.
Are you going for the thicker headgasket too? If your funds can stretch that far I personally would as it allows you to run more boost and it saves taking the majority back out at a later date when you decide to fit a thicker one. Theres also injectors required too.
Any ideas where you may have it fitted?
Look forward to seeing the outcome!
Gaz
