Aerotop Floor Brace fitted !
milocoon
Thanks to Nic from HK for getting me a 103 014 0 CARBING Mid Floor Brace which I believe is the same as a Do-Luck. This is only for Aerotops and it does reduce the "scuttle shake" when the roof is removed. On very poor surfaces it is still apparent but I`m more than happy with the improvement.
You need to cut your carpet so the sides can slot back into the car, due to the extra thickness I had to leave the lock washers off the seat belt anchors. There is already a threaded section in the car sill for the other mounting bolt. Took me a little while to figure out the above but it was fitted in an evening.
here are some piccies, its a very nice fit in the car BTW.
Normal Supra doesn`t really need this, it`s designed for Aerotops which have a more flexible chassis when the roof is removed.
It will fit a fixed head soop, passenger leg room is reduced by 1 1/2" approx or they can raise their heels a little.
It was a special import from Nic ( Import Pimp) so PM him if you want one and you want to save some money.
:tongue:
:tongue:
no but wouldnt it still stiffen the car up more if it were to be a track beast say
I see where you`re coming from, I guess the more the car is braced rear, middle and front the less it will flex / twist. This brace was designed to solve a shortcoming by Toyota when they removed the roof, I`ve read elsewhere the aerotop was stiffened as well but that might be folklore. The scuttle shake is immediately noticeable in a standard aerotop when you remove the roof. I`m pleased to say that this rear floor brace does help to vastly reduce that scuttle in the aerotop. On medium to good roads near to me there is no scuttle shake now with the roof off, on badly potholed roads you can still feel this but it was awful before. With the roof on I can`t detect any difference. The brace itself does appear to be very rigid and an excellent fit.
:p
Guest Garfy
I'm confused, (easy to do I know) but how does that stop scuttle shake, I thought scuttle shake was the front of the car twisting independently from the back, maybe I'm wrong, but if that is the case I can't see how this helps.
The end plates help brace it longitudinally, it will never do the job of a full cage, but these do help brace the aerotop to some extent.
Guest Garfy
But surely it would have exactly the same effect on a coupe as well, this brace is not bridging between the front and back so therefore it isn't offering any more strength where the roof has been removed?
I don't know, but it is confusing me.
