Squeeky noise?
rob_g
would check the wheel bearing first jack car and hold wheel top and bottom "rock it" if any movement its w/bearing while u have the car up spin the wheel check if the pads r rubbing.you have to eliminate things one by one .
but if it was the wheel bearing would they of picked it up in the mot? as it was only cpl of wks ago and it did squeek abit b4 then?
but il have a check and see what i find. fingers crossed its only somthing simple!
  • 2 weeks later...
Guest EncoreWRC
Fiftyplus1- 1- whats tell tail signs?
2- no mice under my car ;)
3- how do i check if pads are stuck? and what do i do if they are?
Dave- Yeh it squeeks goin in a straight line and when turning.
4 - Guinea Pigs in the arches?? :p
SORTED!!
