wkdtime Posted May 7, 2006 Share Posted May 7, 2006 Basically its the first time its happened since by stem seals have been changed, the car has been parked up for two weeks in one place aslso the battery was dead, just started it and it was fine, no blue smoke, left it to warm up on idle for ariund 10 mins, i started to reverse the car out and noticed a cloud of blue smoke which quickly cleared up, drove the car for 10 mins, parked it up and blipped the exhaust and no sign of blue smoke. any ideas guys? Link to comment Share on other sites More sharing options...
bedlam Posted May 7, 2006 Share Posted May 7, 2006 Seals Are letting a little through. Link to comment Share on other sites More sharing options...
wkdtime Posted May 7, 2006 Author Share Posted May 7, 2006 Stem seals are fu**ed again? oil im using is 15w50 mobil one as summers around the corner. Link to comment Share on other sites More sharing options...
Scooter Posted May 7, 2006 Share Posted May 7, 2006 i think he's suggesting the turbo seals could be letting a bit through not the stem seals............ Link to comment Share on other sites More sharing options...
wkdtime Posted May 7, 2006 Author Share Posted May 7, 2006 Oh ok, its not happened since then, whilst warm and in traffic blipped throttle, and when parking the car at home, again nothing. Link to comment Share on other sites More sharing options...
DannoSupra Posted May 7, 2006 Share Posted May 7, 2006 i found this on mine yesterday, just a puff, then nothing - not on rev up either Link to comment Share on other sites More sharing options...
Homer Posted May 7, 2006 Share Posted May 7, 2006 A bit of smoke like that on startup or after a long time idling suggests stem seals. If it were turbo seals it would give blue smoke on boost. Link to comment Share on other sites More sharing options...
wkdtime Posted May 7, 2006 Author Share Posted May 7, 2006 But im confused Homer, wouldnt it do that on start up if it were stem seal which i have recently replaced anyway, i only saw blue smoke after it was running for 10 mins and only when i started to reverse the car out the drive way, surely any oil would have been burnt at start up if it were the stems. Link to comment Share on other sites More sharing options...
bedlam Posted May 7, 2006 Share Posted May 7, 2006 Sorry i should have made my post a little clearer..as 'homer' said a little smoke after the car has sat a long time isnt anything to worry about but i was meaning the stem seals turob seals will cause it to smoke most of the time . Link to comment Share on other sites More sharing options...
Homer Posted May 7, 2006 Share Posted May 7, 2006 But im confused Homer, wouldnt it do that on start up if it were stem seal which i have recently replaced anyway, i only saw blue smoke after it was running for 10 mins and only when i started to reverse the car out the drive way, surely any oil would have been burnt at start up if it were the stems. In my experience, after long time idling the smoke will be much, much greater than any cold start. I sometimes get a tiny bit of smoke on startup but after a long idle it can belch out a good cloud on the 1st blip of the throttle. Mind you its been like this since I bought the car (30k miles ago) so its nothing to worry about Link to comment Share on other sites More sharing options...
wkdtime Posted May 7, 2006 Author Share Posted May 7, 2006 lol cheers homer, bit uplifting that is. Link to comment Share on other sites More sharing options...
