Kranz Posted May 6, 2006 Share Posted May 6, 2006 Hi, Just logged onto this forum, its top bananna Have one small problem with the '93 TT. When the speedo goes over 95 it drops back to 40ish and sits there quivering until the speed drops below 95 again. I don't do this often (yeah, right ) but its annoying more than anything else, and I have to gusee my speed by RPM. I can just see it, I get pulled for speeding and the cop asks "do you know how fast you were going?" "Yeah, about 4800 rpm officer!" Kia Sup Quote Link to comment Share on other sites More sharing options...
Guru Posted May 7, 2006 Share Posted May 7, 2006 I am assuming Jspec so what electronics are converting the speed? Quote Link to comment Share on other sites More sharing options...
Kranz Posted May 8, 2006 Author Share Posted May 8, 2006 Guru, I dunno. Suppose whatever it is its mounted on the back of the speedo? Quote Link to comment Share on other sites More sharing options...
Guru Posted May 8, 2006 Share Posted May 8, 2006 Well I would first take the dash apart and make sure the speedo has no loose plugs or anything and while you're at it check what speed conversion you have. Someone will be able to help probably with this knowledge Quote Link to comment Share on other sites More sharing options...
Kranz Posted August 15, 2006 Author Share Posted August 15, 2006 Resurection time: Finally had the speedo out and fixed the problem. A loose wire that was hanging loose due to a poor crimp terminal. Shocking quality work by the importer. The connector to the odometer had a 3.5mm female std spade connector pushed into a female bullet connector... and badly crimped wires too. Absolute pants! Quote Link to comment Share on other sites More sharing options...
jackso11 Posted August 15, 2006 Share Posted August 15, 2006 about the same as mine was then! for some reason they had put the connecters about 20mm from what each wire was joined onto aswell....didn't leave me with much to play with! Quote Link to comment Share on other sites More sharing options...
