nige Posted April 25, 2006 Share Posted April 25, 2006 with the arrival of new drive through cash machines,customers will be able to withdraw cash,without leaving their car's. please read wichever applies to you. MALE CUSTOMERS. 1 drive up to the cash machine,2 lower your car window,3 insert card into machine enter PIN,4 enter ammount of cash required and withdraw, 5 retrieve card,cash,and receipt, 6 wind up window, 7 drive of. FEMALE CUSTOMERS. 1 drive up to cash machine 2 reverse back the requierd amount to alighn car window to machine 3 restart the stalled engine 4 wind down the window 5 find handbag,remove all contents on to passenger seat to locate card 6 attempt to insert card into machine 7 open car door to allow easier access to machine due to its excessive distance from the car 8 insert card 9 insert card right way up 10 re enter handbag to find diary with PIN written on the inside back page 11 enter PIN 12 press cancel and re enter correct PIN 13 enter amount of cash required 14 remove cash and receipt 15 empty handbag again to locate purse and place cash inside 16 place receipt in back of cheque book 17 drive forwards two metres 18 reverse back to cash machine 19 retrieve card 20 restart stalled engine and pull off 21 drive for three to four moles 22 release hand brake. Quote Link to comment Share on other sites More sharing options...
Tom S Posted April 25, 2006 Share Posted April 25, 2006 Re-Post from here http://www.mkivsupra.net/vbb/showthread.php?t=64881 Quote Link to comment Share on other sites More sharing options...
Guest electricmini Posted April 25, 2006 Share Posted April 25, 2006 Last time I was in Canada, I noticed a lot of the drive-thru cash machines were far too high up on the wall for a normal car! So many people have SUVs that the designers of the machines decided to put them in 4 feet off the ground. So if you're in a normal car, or even a Supe, you're stuffed... One near my friend's house is so bad, you can't even see the screen unless you get out of the damned car Drive thru cash machines..... what a crazy idea! (unless it's 30 below outside, then it's not such a crazy idea...) Quote Link to comment Share on other sites More sharing options...
andrew7 Posted April 25, 2006 Share Posted April 25, 2006 And the "Big Issue" guy normal found intimidating people by normal cash machines wouldn't last long, would he? (big Squishu) )....... Quote Link to comment Share on other sites More sharing options...
Ark Posted April 26, 2006 Share Posted April 26, 2006 snip 21 drive for three to four moles 22 release hand brake. Moles? Quote Link to comment Share on other sites More sharing options...
Gamer Posted April 26, 2006 Share Posted April 26, 2006 Moles? Must be the wind in the willows version of the story. Quote Link to comment Share on other sites More sharing options...
