Guest spoons Posted March 23, 2006 Share Posted March 23, 2006 guys does anyone have a better pic of this, petes fog light conversion diagram i cant make out all the colours and wiring . cheers Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted March 23, 2006 Share Posted March 23, 2006 this any good. it only uses one relay. I did it and have no problems whatsoever.foglight mod.doc Quote Link to comment Share on other sites More sharing options...
jackso11 Posted March 24, 2006 Share Posted March 24, 2006 I don't understand....all 5 bright? there are only 4 lights? Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted March 24, 2006 Share Posted March 24, 2006 presume that the 5th is the centre brake light. AFAIK some Supras only have a reflector but some have a brake light on the boot lid. Mike Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted March 24, 2006 Share Posted March 24, 2006 this is the diagram I used. works fine for me, though I believe the resistors are becoming more difficult to locate. You don't actually need the resistors though, these merely prevent the bulb fail circuit from thinking you've blown a bulb if the fog lights are on, and you depress the brakes. Mike Quote Link to comment Share on other sites More sharing options...
Suprasteve Posted March 24, 2006 Share Posted March 24, 2006 thats right, the boot lid is a working brake light on my car, i assumed that was the same on all jap supras ? this is irrelevant to the method anyway. I didn't use resistors and at first the warning brake light bulb failure light always come on but i sorted out a better earth and this solved the problem. i did try doing it the way Pixelfill suggested, as someone else showed me the diagram ages ago but i personally found the method in my attachment far easier but each to their own. I can get pictures of what i did if it makes it easier to understand. let me know Quote Link to comment Share on other sites More sharing options...
garethr Posted March 24, 2006 Share Posted March 24, 2006 Is this any clearer? http://homepage.ntlworld.com/peter.betts/supra/TechTips/fog_lamp.htm Quote Link to comment Share on other sites More sharing options...
