Footwell Lights Problem
Benzsupra
Anyone know if there is a seperate fuse for the footwell lights? all the other lights are working fine but these have gone out after the light was "accidently" kicked off:complain: . It is not a standard light they have been replaced with led lights. I have reconnected the light but neither footwell light is working. BTW The roof interior light is working.
Thanks
Ben.
Just been and had a look, all other lights working fine, no fuses blown in the engine fuse panel or the one in the drivers footwell. I am absolutely lost now, have taken the lights out and checked them by connecting them directly up to the battery and they work fine. Maybe a relay or something? Just clutching at straws. Any ideas welcome.
They are aftermarket lights, i know cause i put them on. But the wiring i used was from the original ones which are put there by Toyota on the GZ models i think by looking through some old threads on here. Which is why i assumed they must be fused somewhere, they even fade out when you shut the door like the main interior light.
