Sensible additional guages?
SteveR
Would some of you more knowledgable peeps be kind enough inform the likes of me - Supra owners who know little about the deep technical stuf but want to look after our cars as much as is possible - what sort of gauges are sensible to keep an eye on everything and check it's all a-ok. :)
OK Boost gauge is an easy one for us TT drivers, but what about things like;
gearbox oil temp,
engine oil pressure,
engine oil temp,
Air/Fuel ratio?,
Exhaust gas temps,
erm... anything else that can be monitored?
Are these things a sensible idea or only really needed after an extent of modding - if so, what mod demands what above aspect to me monitored?
How easy is it to go about adding such sensors & gauges?
Is gearbox oil something that only needs monitoring if you're doing track stuff/hard driving for extended periods?
Many thanks in advance oh wise people!! :thanku:
I have the following in my car:
Boost, EGT, Fuel pressure, Oil pressure, AFR. The only other one I thought of fitting was the oil temp gauge.
Have you got a pic of your dash you can share, it must be pretty crowded??! ;)
Got to admit tho, I want as many gauges as there are things that really should be monitored. There is the added advantage of them looking cool too - the more cockpit-like my supra can be the better :D
This is the dash. As you can see, i have used both the air vents for the boost and EGT an dhave a pillar mount for the oil and fuel presure. The AFR gauge has since been fitted in place of the clock. The pic also shows 3 other gauges - volts, water temp and something else i cannot remember but these are definitely more for show than function.
Lol like you have time to monitor them in your car!!!!
CJ. I have noticed you have some auto gauges, which ones?
I have an electric oil pressure guage and it doesnt work correctly!
Cheers
I dont have them anymore as I fitted a touch screen in their place so cannot tell you what they were. Sorry!
bit of a thread hijak, am thinking about air fuel ratio and fuel pressure. What the recommended ones?
My boost and EGT gauge is one of these:http://www.spa-uk.co.uk/design/dualgauges.asp
Are these god for AFR + FR?
Edit: i was thinking about the DG 215
Whats best for AFR?
