NEW - UK Spec Front Brake Callipers
Nic
Brand new boxed UK Spec (4 Pot) front brake callipers, price is £330 per pair, including surface post to your door. Fitting Kit and Shim Kit = £20 including postage.
No stock at the moment, but can order more if anyone wants a set.
Nic what does the fitting kit include? I was under the impression these just swapped straight over ?
Kenny, yes they are a straight swap, the fitting and shim kits are required to fit the brake pads.
There are instructions on swapping over the calipers, HERE
Sorry for the :hijack: thread Nic, but could you tell me, are these the same as the larger facelift brakes ? ( hope so ! )
Yes these are the same as the larger brakes were fitted to *some* of the facelift models, ie. 4 pot front calipers and 2 pot rear calipers.
  • 2 weeks later...
I just want to highlight what Nic is selling here,I had mine shipped from Nic in 2 days door to door and these things are huge!,If anyone is gonna do a brake upgrade get your money out now,You wont be disapointed!
Cheers for the recommendation Tim :thumbs: if truth be known though I actually screwed up on you delivery. I advertised the calipers including surface post to UK (as they are bloody heavy), but sent yours by airmail by mistake (ouch!), which was why you received them so quickly :looney:
