RedM Posted April 21, 2005 Share Posted April 21, 2005 I've only just heard of Blackjax in the last few days and I must admit it seems like something everyone should have. I'll certainly be getting one when I get my Supra. I'm a tad unsure about something though. It's an anti-carjacking measure but does it work when your car gets nicked but not in a car-jack? If, for example, someone breaks into the car, somehow gets it started and drives off with alarms blaring etc, does Blackjax still kick in? The Clifford site doesn't make it clear. On another note, I've been reading about Clifford systems being a bit sketchy. Are there any other Thatcham approved manufacturers that offer a Blackjax style device? Quote Link to comment Share on other sites More sharing options...
SupraTT2004 Posted April 21, 2005 Share Posted April 21, 2005 blackjax is not Thatcham approved, it comes on the thatcham approved alarms but if activated the thatcham is void. As I was not allowed this activated on mine due to this. I think clifford are the only company to produce such a product i.e blackjax Well thats what my local alarms dealers have told me anyways. Quote Link to comment Share on other sites More sharing options...
RedM Posted April 21, 2005 Author Share Posted April 21, 2005 WTF?!?! That just makes it even more confusing. What would be the ramifications of using it? Does your insurance become void too? Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted April 21, 2005 Share Posted April 21, 2005 The intellistart and a turbo timer will invalidate your insurance if discovered to of been used when a car is stolen, but I believe the Blackjax system is OK with insurance companies. As for the earlier question as to will it work if the car is broken into not hijacked, then yes it will. When you get in the car to start it, you must enter the code, as the alram has seen the door as being opened. I suppose if the window is broken and then the little shite slid in through the broken window then it would not work, not sure if it works with the windows? Quote Link to comment Share on other sites More sharing options...
SupraTT2004 Posted April 21, 2005 Share Posted April 21, 2005 I dont no then. My alarm fitters which are normally very good with things. told me that they would not give me my thactham approved certificate if blackjax was enabled. oh well. Quote Link to comment Share on other sites More sharing options...
RedM Posted April 21, 2005 Author Share Posted April 21, 2005 The alarm I've been looking at, the Intelliguard 950, has a window alarm too. It's got that much stuff on I bet it'll also be able to predict winning lottery numbers! Quote Link to comment Share on other sites More sharing options...
SupraTT2004 Posted April 21, 2005 Share Posted April 21, 2005 Just passing information on from what I have been told and that is there is not much difference between the 650 and the 950, and it not really worth the extra money. Quote Link to comment Share on other sites More sharing options...
kosmic Posted April 21, 2005 Share Posted April 21, 2005 ...It will work every time a door is opened and closed on the vehicle...a bit annoying if after a while that u gotta enter the code within 45 secs of getting into the car. I have a concept 600 and ive had it turned off...but after Matts horrible last couple of days im gonna start using it. Ideally it is to be used in hi-jack situations where if u are in the car and forced to get out...as the door is opened by you or the hijacker the timer starts, let the hijacker drive off with the car and unless he knows the 4 digit pin (impossible) the car will cut out with all bells a wailing few seconds later.... I believe its an excellent measure for thefts which commomly occur these days when the keys are stolen. In those circumstances the theif drives off not knowing the timer has already begun and 45 secs later..the car will cut out and he will make a run for it... not a very good explanation but i hope that gives u some idea of how blackjax works!! Quote Link to comment Share on other sites More sharing options...
Steve Posted April 22, 2005 Share Posted April 22, 2005 Have been told by a company called SJF Vehicle Security ( found via Google ) that the Blackjax can be run as a standalone system. Cost approx £85 for the unit + fitting http://www.sjfvehiclesecurity.co.uk/html/clifford_accessories.html Quote Link to comment Share on other sites More sharing options...
Supragal Posted April 23, 2005 Share Posted April 23, 2005 ..the car will cut out and he will make a run for it... Hopefully, unless he and the crowbar he used to get into your car is angered Quote Link to comment Share on other sites More sharing options...
michael parker Posted April 23, 2005 Share Posted April 23, 2005 I dont no then. My alarm fitters which are normally very good with things. told me that they would not give me my thactham approved certificate if blackjax was enabled. oh well. I got my 950 fitted about 3 weeks ago and i got my certificate, they don't activate blackjax unless you request it, it takes about 45 mins to activate, all done via a laptop. As for choosing a 600 or 950, my local clifford dealer are doing a deal at the mo where they're throwing in the intellistart (worth £180) with the 950. I believe the 600 is approx £390 fitted and the 950 is £550. The 600 has one option with it, i.e. dual zone proximity sensor (bleeps if someone noses in your car), whereas the 950 has: dual zone proximity sensor, tilt and motion sensor (protect it from someone jacking up ya car and nicking ya wheels/towing ya car away) and a glass tamper sensor (detects screwdrivers etc against the window) and as i said i got the remote start thrown in! i know which one i think is the better deal!!!! Just rung up today to get my blackjax activated, it'll take 45 mins, it's a two digit code you have to type in. If you forget, after driving for about 20 secs it'll give you a warning beep and the brake lights start flashing to warn cars behind the vehicle will be stopping, then after another 10 secs if the two digit code isn't typed in, all power to the vehicle is cut except for the alarm which is sirening and lights that will be flashing!! Sorry this is a bit long winded but i hope it clarifies a few things! Quote Link to comment Share on other sites More sharing options...
RedM Posted April 23, 2005 Author Share Posted April 23, 2005 Any mention of Blackjax invalidating the Cat1 certificate if activated? I've emailed Clifford but they have yet to reply. Quote Link to comment Share on other sites More sharing options...
Simon Posted April 24, 2005 Share Posted April 24, 2005 Cat 1 is basically having an immobiliser (I said basically) and basic alarm. The blackjax should not invalidate the certification because it does not affect the basic operation of the immobiliser when the car has been parked up and locked. Cat 1 does not cover a car that has it's engine running. So blackjax should be ok but turbo timers are not. Quote Link to comment Share on other sites More sharing options...
michael parker Posted April 24, 2005 Share Posted April 24, 2005 The intellistart and a turbo timer will invalidate your insurance if discovered to of been used when a car is stolen, but I believe the Blackjax system is OK with insurance companies. As for the earlier question as to will it work if the car is broken into not hijacked, then yes it will. When you get in the car to start it, you must enter the code, as the alram has seen the door as being opened. I suppose if the window is broken and then the little shite slid in through the broken window then it would not work, not sure if it works with the windows? If your fitting a thatcham cat 1 alarm to get a discount on your insurance, please check that your company give a discount for such a thing, you'd be suprised how many companies do not!!! Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 24, 2005 Share Posted April 24, 2005 The invalidation of Thatcham approval is a massive grey area. The scaremongering came about a few years ago when some young bod at the MIRRC bought a Clifford system with Intellistart. His boss alegedly jumped on the phone and complained that the system was now in breach of the original testing compliance. Now, strictly speaking, ANY alterations you make to the system from the way it comes out of the box means you've invalidated the Thatcham compliance. So, changing the arm/disarm chirps invalidates the approval as much as turning on Blackjax. I've heard all the scare stories, but as yet, I've never, ever, heard of anyone, or any insurance company that has refused to pay out due to changing features on an alarm system. As for not supplying a certificate.... What a load of jobsworth jerks. Blackjax takes about 2 minutes to activate, BTW IMHO, it's an excellent feature, but not for technophobes. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted April 24, 2005 Share Posted April 24, 2005 IMHO, it's an excellent feature, but not for technophobes. why not. To complicated to install? and 2 minutes to activate that seems a very long time for every journey! btw: do you sell them Matt? Quote Link to comment Share on other sites More sharing options...
kosmic Posted April 24, 2005 Share Posted April 24, 2005 why not. To complicated to install? and 2 minutes to activate that seems a very long time for every journey! btw: do you sell them Matt? Matt meant 2 minutes to SWITCH the feature on/off...not activate. Takes about 10-15 seconds to de-arm depending on your pin number. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted April 24, 2005 Share Posted April 24, 2005 LOL, yes thanks kosmic When I say not for technophobes, bear in mind that we have allsorts of customers and some just can't get to grips with entering the code. The fact that it needs to be entered every time you drive the car or a door is opened whilst the engine is running. - And it really freaks some people out when it activates and they can no longer turn it off by remote control Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 25, 2005 Share Posted April 25, 2005 Got to say some of these alarm "features" are just INCREDIBLY annoying when I service a car with them on. I had one guy a bit ago with *THREE* separate alrms on his car. One of them had this damned Blackjack thing activated. Total PITA, what a palavar every time you want to start or move the thing. How the hell people put up with all that i don't know. First thing I do with my car is take the alarm out if it's got one, I just can't be doing with the hassle and often the unreliability of none factory systems. I rate car alarms as in the top 3 of my pet motoring hates Quote Link to comment Share on other sites More sharing options...
Chase Posted April 25, 2005 Share Posted April 25, 2005 I always put mine in valet mode if it needs to be worked on. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 25, 2005 Share Posted April 25, 2005 I always put mine in valet mode if it needs to be worked on. Excellent. (I think, what's valet mode....?). Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted April 25, 2005 Share Posted April 25, 2005 Got to say some of these alarm "features" are just INCREDIBLY annoying when I service a car with them on. I had one guy a bit ago with *THREE* separate alrms on his car. One of them had this damned Blackjack thing activated. Total PITA, what a palavar every time you want to start or move the thing. How the hell people put up with all that i don't know. First thing I do with my car is take the alarm out if it's got one, I just can't be doing with the hassle and often the unreliability of none factory systems. I rate car alarms as in the top 3 of my pet motoring hates I somehow knew you wouldn't like these alarms Chris! Quote Link to comment Share on other sites More sharing options...
