SimonB Posted April 17, 2005 Share Posted April 17, 2005 The probe for my oil temp gauge used to live in the take-off plate for my remote oil filter, but I have now changed this when fitting my oil cooler. I was going to put it in a T connector but it sticks out too much into the oil flow so I had to abandon that idea. So what I think I will do is put it in the sump plug. Does anyone know where you can get a sump plug with a hole with a 1/8NPT thread from? I don't have the equipment to drill a hole and tap a sump plug. Quote Link to comment Share on other sites More sharing options...
paul mac Posted April 17, 2005 Share Posted April 17, 2005 toyota part number for the plug is 90341-12012 price £2.28 take it to any local machine shop and they'll probably do it for a fiver or less, i dont know of any ready made item you could buy Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 18, 2005 Share Posted April 18, 2005 Does the plug need a 1/8 NPT MALE or FEMALE thread? Quote Link to comment Share on other sites More sharing options...
SimonB Posted April 18, 2005 Author Share Posted April 18, 2005 Does the plug need a 1/8 NPT MALE or FEMALE thread? Female, to take the temp probe. I'm not sure what the male thread size and type is on the sump plug itself. Does anyone know - I've just thought I might be able to get an adaptor from Think auto or somewhere if I knew the thread size. Quote Link to comment Share on other sites More sharing options...
Guest Irish Supra Posted April 18, 2005 Share Posted April 18, 2005 Nice idea, but would it get fouled on speed bumps etc. The sump is pretty low as it is and with wiring coming off the nut it would be lower??? Quote Link to comment Share on other sites More sharing options...
SimonB Posted April 18, 2005 Author Share Posted April 18, 2005 Nice idea, but would it get fouled on speed bumps etc. The sump is pretty low as it is and with wiring coming off the nut it would be lower??? Nah it should be OK, the plug is on the side of the sump at an angle and the probe doesn't stick out much. I've found the sump plug thread size, it's M12 x 1.25. So I need an adaptor with a M12 x 1.25 male thread to a 1/8NPT female. Quote Link to comment Share on other sites More sharing options...
SimonB Posted April 18, 2005 Author Share Posted April 18, 2005 Ok, having had a good search round it seems that Blitz make a series of adaptors for different sump threads for different cars, including a M12x1.25 one, part number 19220. Should save trying to find a machine shop! Quote Link to comment Share on other sites More sharing options...
tDR Posted April 18, 2005 Share Posted April 18, 2005 I wouldn't bother with this idea..... I did the very same on my S13 track car and found the readings were useless.. barely registered on the oil temp gauge at all because the oil at the very bottom of the sump isn't hot enough. Best drilling and tapping the sump in the middle for a more accurate reading. Cheers, Brian. Quote Link to comment Share on other sites More sharing options...
paul mac Posted April 18, 2005 Share Posted April 18, 2005 I wouldn't bother with this idea..... I did the very same on my S13 track car and found the readings were useless.. barely registered on the oil temp gauge at all because the oil at the very bottom of the sump isn't hot enough. Best drilling and tapping the sump in the middle for a more accurate reading. Cheers, Brian. have to disagree here mate, have run a sump oil temp for 2 years and it works fine it will give lower readings than straight of the gallery but everything is relative, seeing as the guy is struggling to drill a sump plug i hardly think suggesting drilling the sump is a realistic option Quote Link to comment Share on other sites More sharing options...
SimonB Posted April 18, 2005 Author Share Posted April 18, 2005 have to disagree here mate, have run a sump oil temp for 2 years and it works fine it will give lower readings than straight of the gallery but everything is relative, seeing as the guy is struggling to drill a sump plug i hardly think suggesting drilling the sump is a realistic option Oi, I'm not a complete numpty, I am capable of drilling and tapping ! I just don't own a bench drill, and I'm too lazy to search out a engineering shop that does. Mind you, without a lift or pit I wouldn't fancy lying under the car tapping the sump I must admit. I used to have the probe in the oil filter take off return, so I'm expecting the sump temp to be slightly higher than that. I think as long as you know where the reading is being taken from it shouldn't matter too much if it's sump, the line to the cooler, from the cooler or wherever. Quote Link to comment Share on other sites More sharing options...
tDR Posted April 18, 2005 Share Posted April 18, 2005 have to disagree here mate, have run a sump oil temp for 2 years and it works fine it will give lower readings than straight of the gallery but everything is relative, seeing as the guy is struggling to drill a sump plug i hardly think suggesting drilling the sump is a realistic option Pretty useless readings IMO. Quote Link to comment Share on other sites More sharing options...
paul mac Posted April 18, 2005 Share Posted April 18, 2005 Oi, I'm not a complete numpty, I am capable of drilling and tapping ! no offence intended mate, from your post i guessed you did'nt have the gear to do it so drilling the sump really is'nt an option for most people even if you have the gear, i have never had a problem with the sump readings they are about 20-30 degrees down on the oil coming straight off the block so as long as you bear this in mind there is nothing wrong with reading the sump its just different 95-100 degree sump oil temp at wot is'nt a useless reading IMHO, your other option would be to get a oil filter sandwitch plate and put the sensor in there Quote Link to comment Share on other sites More sharing options...
Dragonball Posted April 18, 2005 Share Posted April 18, 2005 I have seen more than one sump plug knackered as there is so small a gap left once fitted IMHO a much better idea is our remote filter head - that allows you to both move the filter so it is easier to reach and utilise the boss fittings for both oil temp and oil pressure Well worth considering Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 19, 2005 Share Posted April 19, 2005 We run oil temp gauges in the sump plug routinely here at work. Seems to work fine for us. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 19, 2005 Share Posted April 19, 2005 Oil in all wet sump systems is in a state of constant flow and severe agitation, as such all oil is at the same temp to within a degree max. There is a total maelstrom in there, the oil in the bottom of the sump is a fine location for a temp probe. Quote Link to comment Share on other sites More sharing options...
imi Posted February 14, 2011 Share Posted February 14, 2011 Oil in all wet sump systems is in a state of constant flow and severe agitation, as such all oil is at the same temp to within a degree max. There is a total maelstrom in there, the oil in the bottom of the sump is a fine location for a temp probe. Hi all, need some help here Have the following oil temp probe http://www.race-technology.com/content.php?pcat=2&cat=64 What size sump adaptor is required for this to fit? many thanks imi Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted February 14, 2011 Share Posted February 14, 2011 why cant you use a sandwhich plate? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 14, 2011 Share Posted February 14, 2011 It's too big, it's the same diameter thread as the sump plug, but a different pitch. Most are M10 x 1.00 for which I stock adaptors. The smaller sender allows an adpator to be made in the form of a sleeve with a hex on it. Quote Link to comment Share on other sites More sharing options...
