Ian C Posted March 1, 2005 Share Posted March 1, 2005 ...on a facelift non VVTi. Anyone done this yet? Matt Harwood is scoping out his archive tomorrow for me at work, the star, but if anyone else can chip in that'd be great. Toyota, in their infinite wisdom, not only changed a large percentage of wire colours on the facelift, but apparently they have changed the pinouts of the ABS ECU as well I need the four wheel speed sensor wires and they aren't the ones you use on a non-facelift Supra. If anyone knows can they pop the pinouts up on here so I can get de- and re-soldering in the vast open plains of "behind the dashboard"? Ta. -Ian Quote Link to comment Share on other sites More sharing options...
Terminator Posted March 1, 2005 Share Posted March 1, 2005 I think Chris Wilson has done one of these. Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 2, 2005 Share Posted March 2, 2005 Mine is a facelift pre-VVTI. Don't remember having any particular problems with the ABS wires. I'll have a look when I get home because I think I wrote down the colours of the wires I used. Mine is an RZ though, so it has the uprated ABS if that makes any difference. Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 2, 2005 Share Posted March 2, 2005 Ok, this is what I have written down:- ABS wire Colour RLTC wire colour Wheel -------------------------------------------- A21-3 RED RED FR A21-8 WHITE YELLOW FL A20-10 BLUE BLUE RR A20-22 PURPLE GREEN RL Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 2, 2005 Author Share Posted March 2, 2005 Ok, that's cool as the pin numbers are different to what I had. Which connector is the 16 pin one and which is the 26 pin one? Ah, hang on, A20-22, hmm, that won't be the 16 pin connector will it Are you saying that the wires on the ABS loom were the same colours as the RLTC instructions say (white, red, blue, purple) but where on different pins? If so I can simply look for the wire colours - perhaps they haven't changed with the facelift, just the pin positions... -Ian Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 2, 2005 Share Posted March 2, 2005 To be honest I can't remember, it was a while ago, but I think the colours were the same yes. IIRC they are a slightly thicker gauge than the other wires too. I think the pin numbers I have written down relate to the pin numbers on the ABS looms in the car, are there two connectors going to it, can't remember? Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 2, 2005 Share Posted March 2, 2005 Just found the old thread I got the pin numbers from, thought I must have got those from somewhere... Here it is. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted March 2, 2005 Share Posted March 2, 2005 Ian, whatever you do, test them first, don't just connect them. I didn't get to work today as there was a bit too much snow down here, (took me 3.5 hours to travel half way to work! Then on the way back, some twat decided to use my bumper to help himself stop!) Anyway, I'll dig 'em out tomorrow, but if you were planning to do it tonight, give me a call if you have any problems.... Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 2, 2005 Author Share Posted March 2, 2005 Ian, whatever you do, test them first, don't just connect them. Yes Dad Don't worry, I'm not falling for that again! Any info would be good, this looks promising though -Ian Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 2, 2005 Share Posted March 2, 2005 Yes Dad Don't worry, I'm not falling for that again! Any info would be good, this looks promising though -Ian Testing? Where's the fun in that, just solder and go.... Seriously though, I'm pretty confident those are the correct wires. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted March 2, 2005 Share Posted March 2, 2005 Testing? Where's the fun in that, just solder and go.... Seriously though, I'm pretty confident those are the correct wires. So far, I've seen a fair few different variations of ABS ECU... Most of which are on facelift versions! Quote Link to comment Share on other sites More sharing options...
SimonB Posted March 2, 2005 Share Posted March 2, 2005 So far, I've seen a fair few different variations of ABS ECU... Most of which are on facelift versions! I've never managed to figure out why the hell Toyota changed all the wiring for the facelift cars, even before the VVTI when the ECU and the other electronics were the same! They just seem to have changed half the wire colours for no reason at all, and then changed a few plugs too for good measure. I'm sure when I did the blue LED heater control thingy mod the illumination power and ground were round the wrong way from pre-facelift for no reason. Blew up 2 invertors before realising. And then there's the plug that goes to the ignition barrel which is different. Why why why? Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted March 3, 2005 Share Posted March 3, 2005 Tell me about it! - It's caused me a few headaches before too. That's why I check everything now Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 3, 2005 Author Share Posted March 3, 2005 Imagine having a bunch of electrical probs all at the same time like I did this time last year Thanks for this guys, I'll let you know on Saturday how it turns out. -Ian Quote Link to comment Share on other sites More sharing options...
