marc_p Posted September 21, 2015 Share Posted September 21, 2015 ****NO LONGER FOR SALE, LOVE IS BACK FOR IT**** I know I am going to regret this and it's a hard thing to write, but a new Mustang is on the horizon and the Supra needs to go Before I get to the current standing of the car, a breakdown of mods as it is currently: Engine 2JZ-GTE Engine Super Spark Coilpacks Unorthodox Racing Water Pump Pulley Unorthodox Racing Fan Pulley Unorthodox Racing Alternator Pulley Garage Whifbitz Idler Pulley Borg Warner S366 Turbo w/ polished housing Whifbitz Twin Wastegate Manifold 2x Turbosmart 40mm Wastgates 4" Alloy intake pipe Goodridge braided oil feed line Billet alluminium oil drain flanges 3.5" Kakimoto Exhaust System with 4.5" exit K&N Air Filter K&N ICV Filter K&N Oil Filter Whifbitz 3.5" v-band downpipe Carbon Fibre Fuse Box cover TRD Oil Cap Gates Racing Cambelt Gates Racing Fanbelt Garage Whifbitz Magnetic Sump Plug Garage Whifbitz Billet cambelt tensioner bracket Powerhouse Racing Modified Cam Covers Powerhouse Racing Breather System NGK Iridium BKR8EIX Spark Plugs Fuelling AEM 380Lph Fuel Pump Bosch in-tank adapter Sard 800cc Injectors Aeromotive Fuel Pressure Regulator Aeromotive FP Guage Garage Whifbitz Fuel Pulsation Dampner removal hose Garage Whifbitz FPR Fitting Kit Management Motec M600 ECU HKS EVC-S Boost Controller Apexi Turbo Timer Launch Control Programmed Through Motec Traction Control Programmed Through Motec Anti-Lag Programmed through Motec Secondary Lamba O2 sensor programmed through Motec Full Throttle Up-Shift Programmed through Motec Motec Data Logging AEM AFR Gauge TT6 Loom from donor car ABS and TC system from donor car GM 3 Bar MAP sensor MAC Boost Solenoid Cooling AFR Dualcore intercooler Koyorad Radiator APR Carbon Fibre Cooling Plate 3.5" Alloy intercooler piping Whifbitz 72 celcius thermostat Twin Electric Fans Drivetrain V161 6 Speed Getrag Gearbox TRD Gearbox Mount TRD Clutch Line RPS Cyn-R-G Flywheel RPS Stage 3 6-Puck Clutch AP Engineering Shifter Bushes A03B Limited Slip Differential Hubs, driveshafts, etc taken from TT6 donor car Manual gearbox tunnel taken from TT6 Donor Car Chassis Tein Flex Coilovers Tein Electronic Damping Force Control Super Pro Lower Control Arm Bushes, front and rear, inner and outer Super Pro Upper Control Arm Bushes, front and rear inner and outer Super Pro Anti Roll Bar Bushes front and rear Super Pro Subframe Bushes front and rear Super Pro Steering Rack Bushes Super Pro Diff Bushes Subframes taken from TT6 donor car Ultra Racing transmission tunnel brace Driftworks rear camber adjusters Braking UK Spec Calipers Brembo Disks Brembo Pads Goddridge Braided brake lines Interior Gear stick and handbrake gaiters trimmed in black leather with blue stiching Sony double din headunit Boston Audio speakers in place of standard speakers Dash and clocks taken from Facelift TT6 Donor car Carbon Fibre centre console cover New OEM Parts Crank Pulley Cambelt Tensioner Water pump Oil pump Exhaust Gasket Inlet gaskets Fuel Filter That car currently stands me at a figure of above £50k including the original purchase price, which in my opinion, makes my asking price a bit of a bargain. The car is in perfect running condition, the engine has had a full check over and compression and leakdown tests and all is perfect, however, it is not quite finished, on the last mapping session, the clutch was slipping and the fuel pump was struggling to keep up, so it was again dumped on a conservative map and not to exceed 3k rpm to avoid any issue as it couldnt get a good map once the single started to spool, I have my new AEM pump and clutch ready to go in and send the car back for mapping, expecting around 700hp without straining anything too much. I have boxes of spares to go with it In regard to bad points: The paintwork could ideally do with a blow over, the car was originally RSP and it has had a blow over in a lighter shade that is starting to flake in a few places. The car is very loud, I would try and find a quieter exhaust system, it sounds fantastic, but gets annoying quickly. Oil light is on, this would be sorted in the next mapping session though, oil pressure is perfect. ABS Light is on, this is bacause when everything is stripped down to re-paint/replace the drivers side rear sensor broke(very common), so I would supply a brand new sensor and happy to cover any costs associated with replacing it. Current mileage of the car is 76k miles and although it currently has no MOT, it will have one put on for a buyer. Please appreciate that this is not a combo you really come accross Facelift/Aerotop/6 Speed/Single and I can't think of another in existence, this was also done using a FULL TT6 donor car, so EVERY part was swapped, it wasn't your normal engine/gearbox and diff change, it had all subframes, suspension parts, dash, clocks, brakes, it was the entire car and was done at AFR, labour alone amounted to over £3k. So, the bit you all want, the price. Due to it's current standing, I'm happy to offer 2 different price options: As it is £19,000 and buyer has clutch and pump replaced(which I will include with sale) and sent for final map. With the above done £21,000 I think that I have priced the car fairly and even as much as it would break my heart to see it, you could break the car and get back more than the above. Also note that this is a high power single, with adjoining mods, so with the RPS flywheel and clutch and a TRD mount, the gearbox is noisy, with the engine mods, the car is noisy, don't expect it to be quiet and refined Happy to answer any questions and thanks for reading. Will try and get better pics shortly [ATTACH=CONFIG]205162[/ATTACH] [ATTACH=CONFIG]205162[/ATTACH] [ATTACH=CONFIG]205163[/ATTACH] [ATTACH=CONFIG]205164[/ATTACH] [ATTACH=CONFIG]205165[/ATTACH] [ATTACH=CONFIG]205166[/ATTACH] Link to comment Share on other sites More sharing options...
Jamesy Posted September 21, 2015 Share Posted September 21, 2015 what a car Link to comment Share on other sites More sharing options...
Benjy Posted September 21, 2015 Share Posted September 21, 2015 Lovely car mate. Glws! You fool!! Link to comment Share on other sites More sharing options...
JasonR24 Posted September 21, 2015 Share Posted September 21, 2015 Wow this is probably my dream supra right there. Lovely looking car. If I win the lottery this week I'll come get it lol GLWS Link to comment Share on other sites More sharing options...
stevie_b Posted September 21, 2015 Share Posted September 21, 2015 I don't usually chip in to For Sale threads with chit chat, but I will do here. That looks fantastic. I love the OEM look. A real sleeper! Link to comment Share on other sites More sharing options...
Fitz Posted September 21, 2015 Share Posted September 21, 2015 GLWTS Marc Link to comment Share on other sites More sharing options...
Supraleeturbo Posted September 21, 2015 Share Posted September 21, 2015 Sorry to go a little of topic here but how did you find the difference from stock up pads and disks to the brembos? And where do you get them from? Beautiful looking car there mate at a real bargain price this won't hang around for long Glwts mate Link to comment Share on other sites More sharing options...
foggy147 Posted September 21, 2015 Share Posted September 21, 2015 What I would give to buy this back!!!! Link to comment Share on other sites More sharing options...
ellis Posted September 21, 2015 Share Posted September 21, 2015 21 grand apparently! Link to comment Share on other sites More sharing options...
Chris Bailey Posted September 21, 2015 Share Posted September 21, 2015 An absolutely stunning car this! You're a fool for selling really GLWTS Marc great car Link to comment Share on other sites More sharing options...
supersizejim Posted September 21, 2015 Share Posted September 21, 2015 Very tidy. Good spec for the dosh. Good Luck Matey. Link to comment Share on other sites More sharing options...
marc_p Posted September 22, 2015 Author Share Posted September 22, 2015 Thanks for the comments guys, it really is a hard decision to sell this, but the yank V8 itch is just getting too much, always used the excuse of them being LHD to try and put myself off them, but with the new Mustang coming here in RHD, I cannot resist any longer. Sorry to go a little of topic here but how did you find the difference from stock up pads and disks to the brembos? And where do you get them from? Beautiful looking car there mate at a real bargain price this won't hang around for long Glwts mate Can't really help there, I got them with the callipers, so the car went straight from J spec to UK spec with the disks and pads, they are pattern part ones though, no drilled/grooved ones. What I would give to buy this back!!!! It's been an emotional journey of ups and downs and it's certainly come a long way, I honestly believed I would never sell this car, but times change and the funds won't allow another car, I have a new E-Class on order for me and the missus, still have the 944 and R32 GTR and hoping to go lay a deposit down with Ford to get on the Mustang waiting list next month, this car just has too much money in it for the one that gets used the least. An absolutely stunning car this! You're a fool for selling really GLWTS Marc great car I know I am, I very much doubt this will be my last Supra though as I have had 4 of them and never been without one for the past 7 1/2 years. I will probably find myself picking up a nice standard TT6 in the not to distant future, once the R32 peaks in value, I'll more than likely trade out for a standard TT6 as an investment. Link to comment Share on other sites More sharing options...
scott.wild Posted September 22, 2015 Share Posted September 22, 2015 Why did this not come up for sale 5 weeks ago before i made the decision to have my Aerotop resprayed and singled.... Link to comment Share on other sites More sharing options...
EdMorris Posted September 23, 2015 Share Posted September 23, 2015 GLWS, thats a very honest sounding ad. Link to comment Share on other sites More sharing options...
Havard Posted September 23, 2015 Share Posted September 23, 2015 What I would give to buy this back!!!! 21 grand apparently! That made me lol..!! Link to comment Share on other sites More sharing options...
Pig Posted September 23, 2015 Share Posted September 23, 2015 Good luck with the sale Mark - You are so close to the finishing line, I would suggest you fit the clutch, upgrade the fuel pump (You may need to upgrade the size of the power cable to it at the same time) and you will have a cracking car to sell. A VERY well spec'd car that will fit the needs of a serious buyer. There is only one other thing that I would suggest... get that TRD mount off your gearbox, the noise will put people off - I thought mine was faulty when I had it on and it was horrible! Link to comment Share on other sites More sharing options...
marc_p Posted September 24, 2015 Author Share Posted September 24, 2015 Good luck with the sale Mark - You are so close to the finishing line, I would suggest you fit the clutch, upgrade the fuel pump (You may need to upgrade the size of the power cable to it at the same time) and you will have a cracking car to sell. A VERY well spec'd car that will fit the needs of a serious buyer. There is only one other thing that I would suggest... get that TRD mount off your gearbox, the noise will put people off - I thought mine was faulty when I had it on and it was horrible! Thanks Jon. Still fully intend to finish but it's going to be a month or 2 til I get the time, hence putting it up for sale now with the option of someone else doing the last bits. I know what you mean about the TRD mount, I get some crazy gearbox noises under acceleration from 1500-3000 rpm especially. I'll get a normal one back on if I get a chance though. Link to comment Share on other sites More sharing options...
marbleapple Posted September 26, 2015 Share Posted September 26, 2015 Have seen this car a few times and have watched Marc as he has worked on it in his garage. I know the effort and knowledge put into it. Good luck on the sale Marc. Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted September 27, 2015 Share Posted September 27, 2015 Fantastic car and well priced id want similar money. If I didn't have mine id be on the blower GLWS marc, would loved to have seen this in the flesh with any luck it will stay in the club. Link to comment Share on other sites More sharing options...
Abz Posted September 27, 2015 Share Posted September 27, 2015 Good luck Marc, I have been going on Dragonball events with this car since 2011. Very well priced too if you consider how much just a TT6 Aero would set you back alone. Such a stunning car with the roof off, shame you are selling it for a slow Ford. Link to comment Share on other sites More sharing options...
Sheefa Posted September 28, 2015 Share Posted September 28, 2015 Marc Can you post up some pictures of the interior please mate? Cheers Greg Link to comment Share on other sites More sharing options...
marc_p Posted November 4, 2015 Author Share Posted November 4, 2015 Updated first post, it's depressing, but I'm now open to the low-ballers, I have no time left and having to work all the time. I would add that if anyone has anything of a good chunk lower value then I could be open to PX. Link to comment Share on other sites More sharing options...
ashloys Posted November 6, 2015 Share Posted November 6, 2015 Absolutely awesome car dude, nice to see you've kept it so simple on the outside too I hope you either get someone to pay your asking price or you keep it for yourself. Would be a shame to see you take a bad offer on it after all the hard work you've put in. Link to comment Share on other sites More sharing options...
marc_p Posted December 4, 2015 Author Share Posted December 4, 2015 Just to update, the car is now having it's work done, so won't be around for a couple of months, but will hopefully be a turnkey 700hp and ready to go once all work is completed. Link to comment Share on other sites More sharing options...
