LSD Rebuild Q
Jellybean
Had the LSD rebuilt , just drove her 13KM; but she is very noisy, best way to describe it is , as speed increases the diff noise increases but it loud enough to imped listening to the stereo at a sensible level, you can hear the diff turning , it is though there is no oil in it ; similar to the video below
I had an aristo diff in her the last 12 months and she was quiet
Its hard to explain, but do I need to put a few KM on her to quieten down?
LSD: Carbonetic (Has at least 100.000 KM on her)
Oil used: Motul PA 90
LSD Rebuilt
·90179-28006 pinion nut^
·90311-50018 pinion seal^
·90366-38009 pinion bearing^
·90366-50039 pinion bearing^
·41231-14110 crush sleeve^
·90366-54014 side carrier bearings x 2
·96721-31110 side carrier cover o rings x 2
·90311-45013 axle seals x 2
·00295-01281 FIPG sealer
Edited by Jellybean (see edit history)
Hopefully Paul will comment :)
I reckon she is gone , might get a TRD diff
Wondering if I put in a new diff will I need to replace all the parts again?
