Help!!
Red
Help!!!!!
hi guys, I was driving along last night and had to pull out of a junction quickly, so i floored it. The back end came round in line with the car (as it does!) and as this happened there was a lound mechanical clunk/banging noise that came from the rear twice. It was not an engine or exhaust sound, but definately something mechanical. I pulled over and inspected the car and saw nothing obvious so continued. Every now and then the noise happened again (this is quite a violent noise and the whole car shakes :( )
on further inspection (driving around the car park);
the noise happens even at VERY low speeds when cornering
It can drive along at medium/low speeds (40mph) in a straight line without any obvious problems (I havent ventured any faster)
I'm going to try and get it up on the ramps later, but I would really appreciate any suggestions from you guys for things you think i should look for :confused:
Thanks in advance,
Red.
okay, it looks like the diff is gone. sometimes the wheels will turn independently, and then something will catch and they will turn together for a bit, then if you hold one of the wheels, and turn the other, with a bit of force it will 'release' and then just turn easily by itself.
so what do you guys think?? how much is a new/ second hand diff?? and can you get them repaired????
any help much appreciated!!!
Ta!
hi,
I finally managedto get a look under the bonnet today.
the vin says;
trans/axle - W8 AO1A
can anybody decode that for me please??? it should be a manual non turbo!
Many thanks,
Red
W58 - 5 speed box
Ring Gear Size A A (138mm), B (145mm)
Differential Ratio 01 01 (4.083:1), 02 (3.769:1), 03 (3.267:1)
Differential Type A A (Std diff), B (Torsen LSD)
Hope thats some help
