Dazzi Posted August 8, 2010 Share Posted August 8, 2010 SOLD Hi, i have forsale my NA manifold I bought from the States. As most NA owners know when buying a manifold originally designed for a LHD car they tend to hit the steering arm, which this one did. I bolted the manifold to a jig and cut 5mm off each branch to bring the manifold back and off the steering arm and rewelded. I have 3" straight through on my car and with this manifold it is just too loud for my liking. I must admit also i don't like raspy exhausts, which this one does create a bit of. The manifold has been on my car for about 300 miles so has turned a goldy bluey colour from heat. You will need 2 lots of gaskets to make this fit properly because of the engine mounts, I am supplying 1 set. Just to confirm also some of the holes don't line up perfectly so it is quite tight to get it on. If you know a local metal worker in your area they will have no problem widening the holes. I am looking for 150 posted. http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs077.snc4/35227_416782516311_615361311_4710835_1700211_n.jpg http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs037.ash2/35227_416782521311_615361311_4710836_3189065_n.jpg http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs057.snc4/35227_416782526311_615361311_4710837_7479136_n.jpg http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs077.snc4/35227_416782531311_615361311_4710838_6364420_n.jpg Link to comment Share on other sites More sharing options...
Guest Suprastar2009 Posted August 8, 2010 Share Posted August 8, 2010 Did you notice any performance gains with this on? Link to comment Share on other sites More sharing options...
Kirk Posted August 8, 2010 Share Posted August 8, 2010 So tempting.... PM'd Link to comment Share on other sites More sharing options...
w41k3r Posted August 8, 2010 Share Posted August 8, 2010 Going nice and cheap if i wasnt going na-t this would deffo be a purchase id be making Link to comment Share on other sites More sharing options...
Neil-NA Posted August 8, 2010 Share Posted August 8, 2010 I will have it pm sent Link to comment Share on other sites More sharing options...
Guest van_damme_supra Posted October 27, 2010 Share Posted October 27, 2010 what to do with the third lambda?? i have the same one but the lambda's are different + there are only two in this one and need three :s Link to comment Share on other sites More sharing options...
Kirk Posted October 27, 2010 Share Posted October 27, 2010 3 lamdba's?? One is a cat temp sensor which you dont need, the other 2 up by the side of the engine are the lamdba's. Link to comment Share on other sites More sharing options...
Guest van_damme_supra Posted October 27, 2010 Share Posted October 27, 2010 3 lamdba's?? One is a cat temp sensor which you dont need, the other 2 up by the side of the engine are the lamdba's. oops, had a quick look yesterday and i tought it was a lambda thanks mate, made my day Link to comment Share on other sites More sharing options...
