ellis Posted May 6, 2010 Share Posted May 6, 2010 Right - quicky for those in the know! I've sold my HKS BOV to Dani_r and he's sending me his stock BOV to fit to mine. Can somebody detail what pipework etc he needs to remove so that I can whip the HKS off and plumb the stock one straight back in? Any pics greatly appreciated! Pics of the HKS install below. Thanks in advance Link to comment Share on other sites More sharing options...
spidermonkey Posted May 6, 2010 Share Posted May 6, 2010 the standard BOV plumbs into the back/under pipe (the one connecting your HKS one) then recirculates into the pipe (the one with the cap on) that sits in front of the vent part of the HKS unit, you will need to use the small vac pipe thats on the back of the HKS to operate, Link to comment Share on other sites More sharing options...
ellis Posted May 6, 2010 Author Share Posted May 6, 2010 So Dan needs to remove the stock BOV from his with the 2 larger pipes attached? Link to comment Share on other sites More sharing options...
spidermonkey Posted May 6, 2010 Share Posted May 6, 2010 yep, he will need the cap from yours though, make sure you plumb the re-circ in the right way ( it should be pretty explanitory when you see it) Link to comment Share on other sites More sharing options...
scotty71 Posted May 6, 2010 Share Posted May 6, 2010 So Dan needs to remove the stock BOV from his with the 2 larger pipes attached? correct and then needs to use a bung when fitting your HKS Link to comment Share on other sites More sharing options...
ellis Posted May 6, 2010 Author Share Posted May 6, 2010 Chars chaps! Will do! Link to comment Share on other sites More sharing options...
