Chase Posted May 27, 2004 Share Posted May 27, 2004 Just done the ETTC mod and while testing in TTC mode, there's a rattling, scraping metallic noise as soon as I start to produce boost. When I flick back to sequential everything's OK again... Seems to be coming from the area around the turbo furthest from the bulkhead. Any ideas? vid: http://www.chasewebdesign.co.uk/ttc.avi (450K) Cheers Quote Link to comment Share on other sites More sharing options...
carl0s Posted May 27, 2004 Share Posted May 27, 2004 file appears to be corrupt mate Quote Link to comment Share on other sites More sharing options...
questionboy Posted May 27, 2004 Share Posted May 27, 2004 Hi, This is normal after the ETTC mod, When you engage into TTC you will here a loud rattle from your turbo actuator, this will not cause any damage to you car but does become anoying !. If you was that fussy you could alway take it off and replace it with a new one. Quote Link to comment Share on other sites More sharing options...
Chase Posted May 27, 2004 Author Share Posted May 27, 2004 Cheers qb - does it stop when the system is pressurised? Is it because the actuators are old? Carl - try this. Regarding the avi above, I've tried various pieces of software and nothing likes it apart from Windows Media Player and the SPV I recorded it on. Bit weird:conf: http://www.chasewebdesign.co.uk/ttc2.wmv (220K) Quote Link to comment Share on other sites More sharing options...
questionboy Posted May 27, 2004 Share Posted May 27, 2004 When the system becomes under pressure it does seem to reduce the rattleing to a point you cannot here when you are driving but again is normal. As for it being down to the actuator, I don't think it has anything to be with being old they all seem to do it some worst than others. Quote Link to comment Share on other sites More sharing options...
Chase Posted May 27, 2004 Author Share Posted May 27, 2004 OK, just been for another blast. Bit dissapointing below 3500rpm (as I expected) but above 4K way hey and kick down is alot more fun. Just getting a little scrape sound when the boost starts building then a slight squirting noise, then we're off. Anyone know what the squirting noise would be? Quote Link to comment Share on other sites More sharing options...
Paul R Posted May 27, 2004 Share Posted May 27, 2004 Hi, Are you going to the JapUK meet in June mate? Fancy showing me how you did the conversion?? Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
Chase Posted May 27, 2004 Author Share Posted May 27, 2004 Dunno yet Paul, I'll be at the next Mascrat meet if you're going. Should be there for a bit longer next time Mod is a piece of piss to do actually. Parts cost about 3 quid from Maplins and the work took about an hour, including a bit of panicing (always worry about cutting ecu wires ) and finding tools. Quote Link to comment Share on other sites More sharing options...
Paul R Posted May 27, 2004 Share Posted May 27, 2004 Originally posted by Chase Dunno yet Paul, I'll be at the next Mascrat meet if you're going. Should be there for a bit longer next time Mod is a piece of piss to do actually. Parts cost about 3 quid from Maplins and the work took about an hour, including a bit of panicing (always worry about cutting ecu wires ) and finding tools. Mascrat Manor is the JapUK meet isnt it?? Cool. I've always fancied doing the TT conversion. Where did you get the info from to do it? Paul. Quote Link to comment Share on other sites More sharing options...
Paul Laing Posted May 27, 2004 Share Posted May 27, 2004 It'll be the EGCV actuator thats rattling, mine does it in sequential mode, didn't know you could buy these new..... Quote Link to comment Share on other sites More sharing options...
Chase Posted May 28, 2004 Author Share Posted May 28, 2004 Originally posted by Paul R Mascrat Manor is the JapUK meet isnt it?? Sorry dude, getting confused with the Santa Pod thing Quote Link to comment Share on other sites More sharing options...
cashpoint Posted May 28, 2004 Share Posted May 28, 2004 Perfect I was about to post a thread about the rattle, how much are actuators? Quote Link to comment Share on other sites More sharing options...
outatime Posted May 28, 2004 Share Posted May 28, 2004 I've had ETTC done on mine, it rattles loudly after a run in sequential mode - its fine in parellel The rattle appears when I lift off the throttle and goes (temporarily) after it has been on boost. Quote Link to comment Share on other sites More sharing options...
outatime Posted May 28, 2004 Share Posted May 28, 2004 Just to add, in hose TTC the EGCV actuator rattled on mine at low revs and idle. There are a few threads about it: Actuator Rattle Actuator Help Rattle from EGCV/Turbo Area? Quote Link to comment Share on other sites More sharing options...
