i baught the supra :)
Lude
hey all, i got the supra which was on piston heads :)
its a 6 speed twin turbo. RZ-S
http://cdn.images.pistonheads.com/aimg/1438/1438341-3.jpg
http://cdn.images.pistonheads.com/aimg/1438/1438341-5.jpg
http://cdn.images.pistonheads.com/aimg/1438/1438341-7.jpg
http://cdn.images.pistonheads.com/aimg/1438/1438341-2.jpg
spec:
Engine
Apexi Air Filter
Greddy/Trust Front Mount Intercooler With Hardpipe Kit
5Zigen Exhaust System (1st & 2nd Cats Removed)
Envyperformance 1.0 Bar Restrictor Ring
Electronics :
Blitz Fuel Cut Defencer
Apexi Super Air/Fuel Controller
Apexi RPM counter
Greddy Profec Boost Controller
Greddy Turbo Timer
Greddy Boost,oil & water Temp gauges
De-limited Speed/Converted to MPH
Wheels/Suspension/Brakes:
OEM UK 17" Alloys 17x8"Front 17x9.5"Rear
Bilstein Shocks and unknown springs
Front & rear Strut Brace
Do-luck body brace
J-Spec Big Brakes (4 Pots Front 2 Pots Rear)
Cusco Brake Cylinder Stopper
Interior:
Bride Bucket Seats
Aftermarket Steering Wheel
Exterior:
OEM Kit Compromising Of Rear Spats And Sideskirts
Clear Side Indicators
im really happy with it :)
ive got the dyno from a few days ago, 381bhp :)
Edited by Lude (see edit history)
oh i like that, shame a little about the interior, very nice
2 people have said that.
whats the matter with it?
im asuming your refering to the gauges stuck on to the side isist?
i thaught the harnesses were a bit old/faded, but their pritty good .
(seats are Bride so :p )
i suppose the comment was my opinion, i don't like things stuck allover, the the turbo timer, controller and gauges, id much prefer a custom panel with A pillar gauges perhaps
yea i understand, all coments welcome!
i dont know if the Profec controller is setup correctly,
the unit says its set to 1bar, yet it seems to boost to 1.3 in 6th?
then the warning light comes on the controller?
boost controllers cant restrict boost, only raise it, therefore you probably dont have a restrictor ring in the exhaust (or its tooo large) therefore boosting as high as the wastegate will allow it.
Pay your membership too!
thanks dude, it claims to have the restrictor ring in the exhaust, but il need to look into it.
whats the safe level on the stock turbos/engine/injectors?
15PSI?
I think they are the only stock wheels i'va actually liked on a Supra, and that'sdown to them being white :)
I disagree with DNK, i think the dash would look nice painted white. I had a White Trans Am and painted part of the dash white and it looked really smart :)
You had a White Trans Am :rolleyes:your probably right Burt:d but instead of painting it maybe getting it flocked so it had a matt finish would be better
i havent mentiond spraying the dash white?! :p
na its the origonal white, the guy said he had the front splitter sprayed tho as it had been cracked etc.
its suprisinlgy low.
the Supra is far more superior to the 300zx/fairlady.
maybe my Z with the boost turned up would be similar speed, but i trust the 2JZ much more, it sounds sweet as, no taps or rattles or smoke.
