David P Posted January 14, 2010 Share Posted January 14, 2010 N/A 4.083 open diff and casing, suits N/A auto and N/A 5MT, £130. SOLD N/s drive shaft, fit N/A or T.T. with small diff casing (No ABS) £30. SOLD N/s hub assembly, (non ABS) backplate has had lip trimmed off to fit behind U.K. brakes £30. Buyer collects or pays P&P. Perfectly good parts swopped out from my regularly serviced 60k N/A auto, during Torsen and SSV4 upgrade. Link to comment Share on other sites More sharing options...
Wez Posted January 14, 2010 Share Posted January 14, 2010 I will take the diff matey PMed Link to comment Share on other sites More sharing options...
David P Posted January 19, 2010 Author Share Posted January 19, 2010 Bump Link to comment Share on other sites More sharing options...
David P Posted February 3, 2010 Author Share Posted February 3, 2010 Bump Link to comment Share on other sites More sharing options...
Supra_Scott Posted February 4, 2010 Share Posted February 4, 2010 I may be interested in the hub as i have a wheel bearing on its way out, can't remember which side tho. Will PM you later today. Thanks Link to comment Share on other sites More sharing options...
Supra_Scott Posted February 4, 2010 Share Posted February 4, 2010 Just checked and i need an o/s rear bearing! Gutted. Link to comment Share on other sites More sharing options...
David P Posted February 4, 2010 Author Share Posted February 4, 2010 Don't be, Keron will have one Link to comment Share on other sites More sharing options...
Supra_Scott Posted February 5, 2010 Share Posted February 5, 2010 Good point, i'll give him a call. Thanks Link to comment Share on other sites More sharing options...
David P Posted February 7, 2010 Author Share Posted February 7, 2010 Bump Link to comment Share on other sites More sharing options...
David P Posted February 9, 2010 Author Share Posted February 9, 2010 Bump Link to comment Share on other sites More sharing options...
Jonboy Posted February 9, 2010 Share Posted February 9, 2010 Hi David, thanks for pointing me in this direction, what does it mean backplate coverted? and no abs? Thanks mate Link to comment Share on other sites More sharing options...
David P Posted February 9, 2010 Author Share Posted February 9, 2010 The back plate lip has been removed to accomodate the larger U.K. brake disc, this can be left as is, or replaced with yours. There is not an ABS sensor in the hub, so it is only compatible with non ABS Supra's. Link to comment Share on other sites More sharing options...
Jonboy Posted February 9, 2010 Share Posted February 9, 2010 mines got ABS mate, would just the flange part fit mine? Link to comment Share on other sites More sharing options...
David P Posted February 9, 2010 Author Share Posted February 9, 2010 It would fit perfectly, but is not compatible with your ABS fitted Supra. The ABS driveshaft has a castleated rim, and the hub has a sensor mounting hole, with a sensor that registers the passing 'ups and downs'. The ABS, shafts and hubs are O.K. for both ABS, and non ABS Supra's, yet, non ABS shafts and hubs are only good for non ABS Supra's. These are up for grabs because I have fitted an ABS hub and driveshaft to my non ABS Supra on the nearside only. These sensors are to be utilised to feed road speed information to the Suprastick VV4 I am fitting. Supra auto trans speed sensors only give 4 blips per revolution, X 4.083 diff gives around 16 blips per wheel revolution. Using an ABS sensor gives 48 blips per wheel revolution which allows the VV4 ECU to do a better job. Hope that answers your question. Link to comment Share on other sites More sharing options...
David P Posted February 13, 2010 Author Share Posted February 13, 2010 Bump Link to comment Share on other sites More sharing options...
David P Posted April 8, 2010 Author Share Posted April 8, 2010 Bump Link to comment Share on other sites More sharing options...
David P Posted April 17, 2010 Author Share Posted April 17, 2010 Bump Link to comment Share on other sites More sharing options...
David P Posted April 22, 2010 Author Share Posted April 22, 2010 Bump Link to comment Share on other sites More sharing options...
David P Posted May 19, 2010 Author Share Posted May 19, 2010 Bump Link to comment Share on other sites More sharing options...
David P Posted May 23, 2010 Author Share Posted May 23, 2010 Link to comment Share on other sites More sharing options...
David P Posted July 16, 2010 Author Share Posted July 16, 2010 Link to comment Share on other sites More sharing options...
David P Posted September 29, 2010 Author Share Posted September 29, 2010 Link to comment Share on other sites More sharing options...
David P Posted January 18, 2011 Author Share Posted January 18, 2011 Link to comment Share on other sites More sharing options...
David P Posted February 2, 2011 Author Share Posted February 2, 2011 Link to comment Share on other sites More sharing options...
David P Posted July 6, 2011 Author Share Posted July 6, 2011 Link to comment Share on other sites More sharing options...
