single turbo kit
Digital
I'd rather sell it as a kit, but if there is enough interest in the parts I will break. Single turbo-kit, only new parts, including:
-Precision T67 76RSP, T4-flange, .68 A/R ball bearing turbo including oilfeed/return (downpipe-side is 3 inch V-band)
-Turbonetics cast manifold
-XS-Power downpipe including V-band clamp (turbo-side is 3 inch V-band)
-Mine's external wastegate (fits directly to Turbonetics manifold)
-4 inch intake-pipe with AEM airfilter
Only thing you need to do if you want to fit this kit is adjusting your original downpipe and make a (screamer)pipe for the wastegate.
Make me an offer:)
The wastegate comes with an extra spring. I don't know which is allready in there but I guess a 0,9bar spring. The wastegate is 38mm, the exact same size as the Turbonectics wastegate-hole.
Reason for selling is I fitted a Greddy T88 turbo with PHR manifold.
Guest EncoreWRC
So,
First dibbs on oil feed and return please..... and a price would be good if you decide to split......
PM me if you decide to go down that route...
  • 2 weeks later...
