UK spec TT Auto Supra
MATT RR
Sold pending payment and collection
Up for sale is my white 1994 UK spec TT Auto supra. Currently running TTC, set up and mapped to 1.4 bar by Paul @ Whifbits, but not run over 1.2 bar. Main selling point is this has just had brand new UK spec turbos fitted and a full engine re-build 2000 miles ago by Whifbits (see below spec, all belts etc changed as expected, pretty much everything done, rebuilt at 128,000, now on 130,000). This engine has since run on nothing other than Shell V-power, and has had 2 oil and filter changes since the re-build.
Just over a year ago it had new Toyo T1 R's fitted, pretty much full tread left, discs all round and pads, copper brake lines fitted, new fuel lines, new battery, new Toyota radiator, new Toyota heater matrix (fitted by yours truly). Interior is pretty spotless as had a new leather roof lining put in, and all new dash panels.
Top of the range Clifford alarm just fitted with remote engine start, turbo timers, auto windows etc.
MOT till April next year. Private plate has been transferred so its back on a standard plate since the photos.
Bad points (see photos at bottom): couple of dings, 1 on driver door and on passenger door (easily repairable), broken aerial with slight corrosion around it, 1 wing mirror in need of paintinh and 1 damaged wing mirror as pictured, but a spare on hand ready for painting! Just had a quote, this can all be fixed for - £350
Think that’s about it, I will edit as I remember anything else, and in response to any questions. Loads of recipts and history present. Not in a rush to sell, and been a rare UK spec with +£6k just spent on the engine and turbos alone asking price seems fair. Wheels alone worth +£3k, and Recaro seats and runners just fitted fully re-trimmed in black with white stiching which cost over £1k in total!
Asking price £8400
Engine Specifications:
HKS 264 cams
HKS K&N filter
HKS plugs
FMIC
TRD Thermostat
Full engine re-build by Garage Whifbitz @ 128k:
Re-bored to 86.5mm
Reface Block
Recon cylinder head
CP pistons/rings
Eagle H Beam Rods
New Oil Pump/Water Pump
New head & turbo gaskets
Gates Cambelt
ARP main studs
ARP head studs
ACL big end bearings
ACL main bearings
ACL thrust washers
Clifford Alarm:
Remote Engine Start
Turbo Timer
Auto Windows
Turbocharger & Induction:
Brand new stock UK spec turbos @128k
Blitz sbci-d set at 1.25 bar
HKS mushroom filter
Fuel, Tuning & ECU:
Greddy Emanage
Walboro pump
HKS FCD
Exhaust:
HKS Superdragger
Drivetrain:
Std. auto box
Weight Reduction & Transfer:
N/A
Suspension, Wheels, Tires & Brakes:
Tein Superstreets
19" Braid 1fm split rims in gold/silver
Toyo T1R tyres
Porterfield pads
3g discs
Interior & ICE:
Recaro Speed seats re-trimmed in black leather with white stitching
Momo wheel
Handbrake Gater
Uprated ice, stealthy installation
Exterior:
Std White
J-spec bonnet
Performance:
Max power - 337 bhp @ rear hubs
Max torque - 340 lb/ft
Max speed - 180 mph +
0-60 - 4-5 seconds
Damage Pics
Just for the sake of any interested parties, this used to be my car. With the exception of the dents the car is in very good condition, especially the interior which is like new.
I had the car for 2 years before Mat, and in that time it had regular fluid changes and was always run on optimax.
I Purchased the car from Whifbitz in 2006, which is where Matt took the car to have the engine work carried out, on my recommendation.
The car is very quick, having seen off an Aston DB9 amongst others in the past.
Paul Whiffin supplied the car with a RR graph, which showed it to be running 455HP at the flywheel when it was setup in sequential mode. It feels faster now it's running in TTC. Paul Whiffin mapped the Emanage correctly for TTC mode.
  • 2 weeks later...
  • 2 weeks later...
