Lurch Posted August 6, 2009 Share Posted August 6, 2009 Hello, I have J-spec TRD kph clocks and was wondering how to convert it to mph? I know about the Thor converter, but do I have to change the clocks? and what clocks can I change to? I've been offered 180mph clocks, would that be right? How do I get the kilometers to be converted to miles? Link to comment Share on other sites More sharing options...
stevie_b Posted August 6, 2009 Share Posted August 6, 2009 You don't need to change the clocks at all if you choose something like the Thor converter (recommended). Your cspeedo should go up to 180kph. The Thor unit will change that to 180mph. Link to comment Share on other sites More sharing options...
Lurch Posted August 6, 2009 Author Share Posted August 6, 2009 Oh I see, so it will actually be mph even though its reading kph. That's good, thank you. Link to comment Share on other sites More sharing options...
stevie_b Posted August 6, 2009 Share Posted August 6, 2009 Yes. To finish the job, all you'll need to do is to replace the "KPH" sticker in the middle of the speedo dial with on that says "MPH". Link to comment Share on other sites More sharing options...
SteveR Posted August 6, 2009 Share Posted August 6, 2009 Yes. To finish the job, all you'll need to do is to replace the "KPH" sticker in the middle of the speedo dial with on that says "MPH". Actually that depends... Some TRD speedo faces read up to 320kph - which is yours (question to the OP)? Link to comment Share on other sites More sharing options...
jacko Posted August 6, 2009 Share Posted August 6, 2009 If you put a new dial face in i'll give you £10 for the TRD one Link to comment Share on other sites More sharing options...
AlexKeith Posted August 6, 2009 Share Posted August 6, 2009 Remeber to make sure the Thor convertor is on setting 8 when fitting to save a hole lot of hassel Link to comment Share on other sites More sharing options...
Lurch Posted August 6, 2009 Author Share Posted August 6, 2009 yes i think it goes to 320kph... ill look when i get home. ill post a photo too. How comes these TRD clocks are so expensive? Link to comment Share on other sites More sharing options...
SteveR Posted August 6, 2009 Share Posted August 6, 2009 yes i think it goes to 320kph... ill look when i get home. ill post a photo too. How comes these TRD clocks are so expensive? rareish Link to comment Share on other sites More sharing options...
Lurch Posted August 6, 2009 Author Share Posted August 6, 2009 Can I still convert these clocks? Link to comment Share on other sites More sharing options...
SteveR Posted August 6, 2009 Share Posted August 6, 2009 Can I still convert these clocks? Yes, but also, no - you don't need a convertor. Ignore mph/kph for the time being, forget the speedo has numbers on it, and think purely about where the speedo needle points. e.g. the 12 o'clock position is approx 80mph (from memory!). the 3 o'clock position is 130mph ish. On your kph speedo I'm going to guesstimate that those 2 positions are - *quick calculation* - 130kph and 210kph, am I right? If I am, you just need to change the speedo face - if you were to fit a speed signal convertor, it'll be all wrongified and you'd get a 5/8ths reading Vs your road speed. On most imports, with a kph face, those two speedo needle positions would be 80KPH and 130KPH, hence the need for a conversion. Link to comment Share on other sites More sharing options...
Lurch Posted August 6, 2009 Author Share Posted August 6, 2009 Any idea where I can get new mph face from that will work with my clocks? What can I do about the odo meter (Not that im too bothered about that!) Link to comment Share on other sites More sharing options...
SteveR Posted August 6, 2009 Share Posted August 6, 2009 Any idea where I can get new mph face from that will work with my clocks? What can I do about the odo meter (Not that im too bothered about that!) ANY standard Supra face will work with your needle if the current face is laid out as I described. Ideally you want a "M/H" face (UK only?), but if you get a "KM/H" one just cover up the "K" - the key thing is the positioning of the numbers on the face. You wil need a speedo convertor to alter the odo, however have a hunt about behind the dash to see if it's already go one - I'm not sure what may have been altered to enable a 320kph speedo face to read correctly, in theory it may be a suitible convertor, that you will just need to rewire slightly to send that 5/8ths signal to the odo as well as the speedo. Link to comment Share on other sites More sharing options...
Lurch Posted August 6, 2009 Author Share Posted August 6, 2009 Ok I'll double check my clocks tomorrow when i get in from work and post on here if they are as described. If they are then ill look for uk spec clocks and see if they match. Can I swap the whole set of clocks so I can sell the TRD ones or will that makes things very wrong? Thanks for your help much appreciated!! Link to comment Share on other sites More sharing options...
SteveR Posted August 6, 2009 Share Posted August 6, 2009 Ok I'll double check my clocks tomorrow when i get in from work and post on here if they are as described. If they are then ill look for uk spec clocks and see if they match. Can I swap the whole set of clocks so I can sell the TRD ones or will that makes things very wrong? Thanks for your help much appreciated!! I haven't ever studpied the TRD clock faces but I think the layout of the rest (fuel, temp, revs, etc) is the same, so you should be able to take them apart and swap them ALL over then sell them on, no worries. The biggest issue is putting the needles back on in the right position, otherwise all the readings are bollxed. Link to comment Share on other sites More sharing options...
jacko Posted August 6, 2009 Share Posted August 6, 2009 I made a little mark on the casing where the needle was - i got the speedo face from ebay, seems to be ok Link to comment Share on other sites More sharing options...
Lurch Posted August 7, 2009 Author Share Posted August 7, 2009 (edited) These are my clocks... I've had a look for some photos of clocks, but nothing seems to be right. There all 180mph clocks which are in totally the wrong place for my needle... Has anyone got any photos of U.K spec dials? Edited August 10, 2009 by Lurch (see edit history) Link to comment Share on other sites More sharing options...
Lurch Posted August 7, 2009 Author Share Posted August 7, 2009 (edited) I found this image from thor racing... It looks like U.K spec dials. If you look at the where 120 km/h is on this photo compared to my dials the 120 km/h seems to be set slightly to the left in these dials. What do you think? Edit: Saying that it might be spot on as the dials never give a true reading do they? or not out enough to worry about... http://www.thor-racing.co.uk/images/Supra_dials.jpg Edited August 7, 2009 by Lurch (see edit history) Link to comment Share on other sites More sharing options...
Lurch Posted August 10, 2009 Author Share Posted August 10, 2009 can these converters be adjusted very slightly? Link to comment Share on other sites More sharing options...
SteveR Posted August 10, 2009 Share Posted August 10, 2009 (edited) I've had a look for some photos of clocks, but nothing seems to be right. There all 180mph clocks which are in totally the wrong place for my needle... Read back to what I said about the position of the numbers - your setup is perfect for you you can swap your speedo face for a MPH one without fitting an adjustor. Yes, but also, no - you don't need a convertor. Ignore mph/kph for the time being, forget the speedo has numbers on it, and think purely about where the speedo needle points. e.g. the 12 o'clock position is approx 80mph (from memory!). the 3 o'clock position is 130mph ish. On your kph speedo I'm going to guesstimate that those 2 positions are - *quick calculation* - 130kph and 210kph, am I right? EDIT = YES! If I am, you just need to change the speedo face - if you were to fit a speed signal convertor, it'll be all wrongified and you'd get a 5/8ths reading Vs your road speed. On most imports, with a kph face, those two speedo needle positions would be 80KPH and 130KPH, hence the need for a conversion. Edited August 10, 2009 by Pixelfill fixed quote (see edit history) Link to comment Share on other sites More sharing options...
Lurch Posted August 10, 2009 Author Share Posted August 10, 2009 Right I might be being thick here but need to make sure... Can I buy complete set of U.K spec dials and swap them over and adjust the needle slightly so they are perfect or do I have to buy a mph face and adjust that so that it sits matching the numbers e.g. 120kph to 74mph and so on? Cheers Link to comment Share on other sites More sharing options...
Lurch Posted August 12, 2009 Author Share Posted August 12, 2009 I've never taken a speedo out so I'm not sure how they work... Link to comment Share on other sites More sharing options...
SteveR Posted August 14, 2009 Share Posted August 14, 2009 Right I might be being thick here but need to make sure... Can I buy complete set of U.K spec dials and swap them over and adjust the needle slightly so they are perfect or do I have to buy a mph face and adjust that so that it sits matching the numbers e.g. 120kph to 74mph and so on? Cheers I believe so, yes. Link to comment Share on other sites More sharing options...
benkei Posted August 14, 2009 Share Posted August 14, 2009 Don't take the needles off!!! Link to comment Share on other sites More sharing options...
Lurch Posted August 14, 2009 Author Share Posted August 14, 2009 Right, brilliant. I shall search for 220mph u.k speedo now. Thanks alot for your help!! Very much appreciated! Link to comment Share on other sites More sharing options...
