Oil Cooler with built in fan
dude
How would you install this then dude if you wanted it for an auto cooler?
I would mount it under the pass headlight and just run out of your stock trans cooler into this and then back to the box, or lose the stock cooler completly and just run the feed and return to this cooler, this was one of 3 i had in the silver car!!!
Will there be any gain in fitting this to a stock auto tt?
Only that the trans oil will run cooler and heat does kill transmissions. depends on how hard you like to drive dude.
  • 3 months later...
