Diff ratio & ring gear size
Homer
I'm trying to put together a file which will calculate all in gear ratios based on tyre & wheel size, gearbox and diff, but I'm stuck on the final drive ratio (i.e ratio between the prop shaft rpm and driveshaft rpm)
As an example, would a A02 diff (138mm ring gear and 3.769 diff ratio) have the same final drive as an B02 diff (145mm ring gear and 3.769 diff ratio)
Can anyone confirm if this is correct?
EDIT:
Or is the ring gear size irrelevant since the gear and pinion sizes are proportial between A and B specifications? I.e. only the ratio is important (01/02/03)? After a bit more looking I now think this is correct.
Cant help but looking forward to the results :thumbs:
It's pretty trick Wez :D Not entirely done by me, it was made by someone on the mustang forum, just trying to get it working (and significantly expanded) for use on the supra :)
