thor tsd & dsc (new.. never fitted)
Guest carrotts
will this fully de restrict the supra?
what i mean is, will this do the job and you wont need anything else, aside from dials obv..
if so, and its suitable for my na auto j spec im very interested.
Guest carrotts
the dials wont need to be changed and it will fully de-restrict.. i'm not 100% if its good for an auto NA though.. if anyone could help with that it would be nice
Hmm, well at some point [before i owned it] my dials have been replaced with 115mph dials, so i am guessin i would still have to swap the faces of these at least to get a correct reading..
would you take £80 delivered, if this will indeed do the trick on my NA Auto :)
This is confusing me a bit I've got a na 5 speed atm but I'm planning on doing a twin turbo conversion will I need a new one after also I have 115 mph clocks and my milage clocks up in miles but my cars defiantly still restricted so will I need different clocks ? If anyone can clear this up and this will be ok
The Delimit bit connects 1 wire to the ECU. Disonnect that before changin from NA to TT ECU and then reconnect it to the TT ECU. Done.
Yes, you'd need a speedo face that has 80MPH at (from memory, roughly the...) 12 o'clock position. Alternatively a typical J-Spec speedo face that has 80km/h at the 12 o'clock position, and as part of fitting the delimit/convertor you simply cover up the "k" so it then reads as "m/h".
HOWEVER, if your car's odo really is counting up in miles, you already have some sort of a convertor installed. It may or may not be able to convert the speedo signal. Check that out as you might not need to buy a convertor, justa delimiter. If in doubt, remove what's there and fit a Thor or other reputable, known unit.
