SteveR Posted February 9, 2009 Share Posted February 9, 2009 I'm being thick no doubt but I've sold my RLTC to a member and don't want him to have any difficulties when to comes to using the thing. This is what was stripped from my car: There is the controller with the knob for choosing how much/little slip you want (and "off"), a load of wiring, and the 'brain'. So where do you pug the serial connector in to programme it?!? I never got round to programming it when I bought the car as Jake reported it was set up for a different wheel size, thus was getting spurious operation and so it was always switched off. Ryan removed all the RLTC kit from my car when I went Solaris, but I still can't actually see how I would have programmed it? I thought it was done with a laptop and via a 9 pin din 9 pin din lead? TIA! Quote Link to comment Share on other sites More sharing options...
SteveR Posted February 9, 2009 Author Share Posted February 9, 2009 Looking at the fitting instructions on our American friend's website, I can see the serial cable is included, but where is it plugged in? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted February 9, 2009 Share Posted February 9, 2009 Isnt it on the back Steve? I have the digi adjuster version, so im not sure on the analogue one. Quote Link to comment Share on other sites More sharing options...
SteveR Posted February 9, 2009 Author Share Posted February 9, 2009 Isnt it on the back Steve? I have the digi adjuster version, so im not sure on the analogue one. lol I'm not sure mate and I already packaged it all up ready to post! It probably is, I'm looking at the online manual at the moment for clues - page 6 shows it connects to 'the brain'. edit - I don't think it matters what adjustor you have as I believe they are interchangeable. Quote Link to comment Share on other sites More sharing options...
paul mac Posted February 9, 2009 Share Posted February 9, 2009 the rs232 plug is on a flying lead attached to the main plug it would appear yours may have been chopped off are you sure its not been raveled up in insulation tape Quote Link to comment Share on other sites More sharing options...
jevansio Posted February 9, 2009 Share Posted February 9, 2009 Steve as Paul says it's a flying lead coming from the smaller of the 2 ECU plugs, if you wish I can take closeup photo's of the plug & the pinout on the RS-232 connector, only 3 of the 9 pins are used Quote Link to comment Share on other sites More sharing options...
jevansio Posted February 9, 2009 Share Posted February 9, 2009 Here are closeups of the plugs, on the serial connector (note it's upsidedown, that's Pin 6 at the top right): Blue - Pin 2 Red - Pin 3 Green - Pin 5 On the RLTC plug I don't know how the pins are numbered but looking from the back of the plug, the 2 on the bottom row are for the diagnostic led: Green - Pin 2 Red - Pin 3 Blue - Pin 4 Quote Link to comment Share on other sites More sharing options...
SteveR Posted February 9, 2009 Author Share Posted February 9, 2009 Doh! At least it's an easy fix to put right then; those close up photos are spot on! I'll contact the buyer and see if he wants me to do this or if he feels confident to sort it out. Many thanks Paul, Jay Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted February 10, 2009 Share Posted February 10, 2009 Doh! At least it's an easy fix to put right then; those close up photos are spot on! I'll contact the buyer and see if he wants me to do this or if he feels confident to sort it out. Many thanks Paul, Jay Double DOH! Sorry Steve, It was because we were rushing to get the stuff out for you before the Train. The Serial connector must be down the side of the gearbox tunnel behind the carpet. If you cant find it send it to me i will fix chap, as i cut it. Ryan Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted February 10, 2009 Share Posted February 10, 2009 Saying that Steve, you might find the small plug and Serial cable are still in the car by gearbox tunnel as i think i left it still connected, due to i will be using the ABS signals cables when setting up the TC etc. Ryan Quote Link to comment Share on other sites More sharing options...
SteveR Posted February 10, 2009 Author Share Posted February 10, 2009 ok thanks Ryan I'll have a nosey when I get in tonight Quote Link to comment Share on other sites More sharing options...
den1 Posted February 10, 2009 Share Posted February 10, 2009 (edited) Hell Folks:hi:. This wont be a problem:). A normal serial RS232 Female connector With pin No-2-Tx=blue.... pin No-3-Rx=red....pin-No-5-grn=green.... What does interest me is where I could find the "ECU"... ECM multi plug/socket (80-pin) & (70&40-pin) that is found on the Supra. Also, spare male/female pins & punch down tool, so I can try to make my own home made patch cable (Fields Harness) ...Plus of course the 26 pin & 16 pin sockets for the RLTC. Edited February 10, 2009 by den1 more info (see edit history) Quote Link to comment Share on other sites More sharing options...
