Alpine CDA-9856R Unit
ellis
Due to having my new double DIN unit fitted (http://www.mkivsupra.net/vbb/showthread.php?p=2233469#post2233469) I now have this Alpine CDA-9856R single DIN unit up for sale. Scoured the internet for the lowest price new and it looks to be about £130.00 plus £8 delivery. Happy to let this go for £70 plus whatever the postage is. All the wires that you see in the pic are also with it as well as the case for the face unit (flip-off) so will send those as well. Any queries or questions, just ask away!
Spec below and pics.
http://img129.imageshack.us/img129/6642/alpineunitqx4.jpg
SPECIFICATION:
  • 50W MAX x 4 High Power Amplifier
  • 3 PreOuts (2V)
  • RDS Tuner
  • Full iPOD control with optional KCA-420i (extra £50.00)
  • CD-R/RW Playback
  • MP3/WMA Decoder/Playback
  • MP3 Text Information Display
  • QuickSearch Function (MP3 Files)
  • CD Text, CD Text Display, CD Text Scroll
  • CD Shuttle Control Function
  • Versatile-Link™ Ready
  • Full Dot Biolite
  • Auxillary input with optional KCA-235 lead
  • Dual Illumination (Green/Red)
  • Bass Engine
  • OEM Steering Remote Ready (optional adaptors required)
  • Vehicle Display Ready (optional adaptors required)
  • Pop-up rotary knob
  • Anti-Theft Flip down detachable Panel
  • RRP £299.99
  • 3 weeks later...
Can only find this:
# Alpine CDA-9856R
# 50W MAX x 4 High Power Amplifier
# 3 PreOuts (2V)
# RDS Tuner
# Made for iPod® with optional KCA-420i
# CD-R/RW Playback
# MP3/WMA Decoder/Playback
# caraudiosecurity.com
# MP3 Text Information Display
# QuickSearch Function (MP3 Files)
# CD Text, CD Text Display, CD Text Scroll
# CD Shuttle Control Function
# Versatile-Link™ Ready
# Full Dot Biolite
# Dual Illumination (Green/Red)
# Bass Engine
# OEM Steering Remote Ready (optional adaptors required)
# Vehicle Display Ready (optional adaptors required)
# Pop-up rotary knob
# Anti-Theft Flip down detachable Panel
And this from the user guide:
FM TUNER SECTION
Tuning Range 87.5 – 108.0 MHz
Mono Usable Sensitivity 0.7 μV
Alternate Channel Selectivity 80 dB
Signal-to-Noise Ratio 65 dB
Stereo Separation 35 dB
Capture Ratio 2.0 dB
MW TUNER SECTION
Tuning Range 531 – 1,602 kHz
Sensitivity (IEC Standard) 25.1 μV/28 dB
LW TUNER SECTION
Tuning Range 153 – 281 kHz
Sensitivity (IEC Standard) 31.6 μV/30 dB
CD SECTION
Frequency Response 5 – 20,000 Hz (±1 dB)
Wow & Flutter (% WRMS) Below measurable limits
Total Harmonic Distortion 0.008% (at 1 kHz)
Dynamic Range 95 dB (at 1 kHz)
Signal-to-Noise Ratio 105 dB
Channel Separation 85 dB (at 1 kHz)
PICKUP
Wave length 795 nm
Laser power CLASS I
GENERAL
Power Requirement 14.4 V DC
(11–16 V allowable)
Maximum Power Output 60 W °— 4 (CDA-9857R)
50 W °— 4 (CDA-9856R)
Maximum Pre-Output Voltage 4V/10K ohms (CDA-9857R)
2V/10K ohms (CDA-9856R)
Bass +20/-14 dB at 60Hz
Treble ±14 dB at 10 kHz
Weight 1.6 kg (3 lbs. 8 oz)
CHASSIS SIZE
Width 178 mm (7")
Height 50 mm (2")
Depth 160 mm (6-1/4")
NOSEPIECE SIZE
Width 170 mm (6-11/16")
Height 46 mm (1-13/16")
Depth 24 mm (15/16")
