couv3z Posted December 17, 2008 Share Posted December 17, 2008 hi guys getting hold of a second hand FMIC, but i'll need to replace the hoses, any of our traders got a replace kit for a Greddy 2 row or, is there a unversal replacement kit? Link to comment Share on other sites More sharing options...
couv3z Posted December 21, 2008 Author Share Posted December 21, 2008 bump Link to comment Share on other sites More sharing options...
Steve Posted December 21, 2008 Share Posted December 21, 2008 The best thing to do is to measure the pipes and then go to somewhere like http://www.viperperformance.co.uk and order the exact ones you want. I can measure the pipe work for you later if you want Link to comment Share on other sites More sharing options...
Steve Posted December 21, 2008 Share Posted December 21, 2008 Turbo to 1st pipe = ? - 68 mm (don't know the turbo outlet size) 1st pipe to 2nd pipe = 72 mm - 72 mm 2nd pipe to I/C = 72 mm - 72 mm I/C to 3rd pipe = 72 mm - 82 mm 3rd pipe to 4th pipe = 82 mm - 82 mm 4th pipe to throttle body = 82 mm - 80 mm If you can get close to these sizes or slightly bigger you should be fine Link to comment Share on other sites More sharing options...
couv3z Posted December 21, 2008 Author Share Posted December 21, 2008 cool, just so i'm clear the measurement is the size of the diameter (sp?) Link to comment Share on other sites More sharing options...
Steve Posted December 22, 2008 Share Posted December 22, 2008 Yes mate, they are the diameter of the pipes. So you will need to get hoses which have these measurements as the internal diameter (or the closest you can get) Link to comment Share on other sites More sharing options...
