MaveriK Posted December 12, 2008 Share Posted December 12, 2008 (edited) And no its not the misses telling me i am going too fast. Sounds like its coming from back passenger wheel but its hard to trace and as stated its intermittent. Any ideas? If it were a bearing in the wheel or gearbox would it not be constant? Edited December 12, 2008 by MaveriK (see edit history) Link to comment Share on other sites More sharing options...
Stonkin Posted December 12, 2008 Share Posted December 12, 2008 If your wheel bearings are on the way out, they will will generally make more noise when cornering (as far as i know) Jack the car up and wiggle the wheels at equal positions all around to see if there is any play Link to comment Share on other sites More sharing options...
bodilx6 Posted December 12, 2008 Share Posted December 12, 2008 Might it be you differential? When is the sound noticeable? When constant throttle @ a certain speed or? Link to comment Share on other sites More sharing options...
MaveriK Posted December 12, 2008 Author Share Posted December 12, 2008 There does not seem to be any pattern to the noise, can be rolling forward slowly or at pace. The note seems to change pitch if the brakes are applied but that could be me going mad. Link to comment Share on other sites More sharing options...
Dnk Posted December 12, 2008 Share Posted December 12, 2008 Wheel bearing would be where i'd look 1st and its easy to check. Link to comment Share on other sites More sharing options...
MaveriK Posted December 12, 2008 Author Share Posted December 12, 2008 Well, its the fecking caliper apparently, took it to a garage in the end as i was getting no where with it. Its seized and taken the pads and disc with it, didnt feel anything like that bad while driving it, i must be losing it! And to cap it off £632 to replace caliper, disc, pads etc, i feel sick. Link to comment Share on other sites More sharing options...
Dnk Posted December 12, 2008 Share Posted December 12, 2008 Well, its the fecking caliper apparently, took it to a garage in the end as i was getting no where with it. Its seized and taken the pads and disc with it, didnt feel anything like that bad while driving it, i must be losing it! And to cap it off £632 to replace caliper, disc, pads etc, i feel sick. Ouch !! who did you take it to, Toyota ? Link to comment Share on other sites More sharing options...
MaveriK Posted December 12, 2008 Author Share Posted December 12, 2008 MCC in Melksham, they have been good to me in the past. Did not want to risk driving it too far either, wish i had had more time and i could have gone to Nic and got Uk replacements. Did i mention the sickness i was feeling? Link to comment Share on other sites More sharing options...
Stonkin Posted December 12, 2008 Share Posted December 12, 2008 maybe time to change the sig? Link to comment Share on other sites More sharing options...
MaveriK Posted December 12, 2008 Author Share Posted December 12, 2008 Been worked over again When will it end Slowdog is dead, long live MCC I should have upgraded my brakes before they broke me Any or all of the above? Link to comment Share on other sites More sharing options...
Dnk Posted December 13, 2008 Share Posted December 13, 2008 Cant see where the £600 + comes from unless theyve clobbered you on the parts or there hourly rate is £100 + phr caliper £200 disc £75 pads £50 Link to comment Share on other sites More sharing options...
MaveriK Posted December 13, 2008 Author Share Posted December 13, 2008 Waiting on the bill to see where the money has been spent, i totted up the costs last night and got the feeling that they were charging me for 6 hours odd. Link to comment Share on other sites More sharing options...
Dan8 Posted December 13, 2008 Share Posted December 13, 2008 that sounds a bit odd i would of thought wheel bearing did they road test it & what if they do all this & its still there & the bearing wants doing Link to comment Share on other sites More sharing options...
MaveriK Posted December 14, 2008 Author Share Posted December 14, 2008 Yes, it was road tested. If its still there after the work i shall be even more un-impressed than i am right now Link to comment Share on other sites More sharing options...
Dnk Posted December 14, 2008 Share Posted December 14, 2008 Have you seen the siezed caliper, worn disc and pads they removed from your car ? Link to comment Share on other sites More sharing options...
