Guest skans789 Posted November 3, 2008 Share Posted November 3, 2008 Hello There My Car does'nt start when its cold but once you put Carbereter Cleaner in The choke it Fires Up With A Little Problem But Does start once ive put the cleaner in, Any ideas what it Is?? Thanks Quote Link to comment Share on other sites More sharing options...
plus1 Posted November 3, 2008 Share Posted November 3, 2008 What car have you got? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 3, 2008 Share Posted November 3, 2008 Are you sure you have a Supra? they don't have a choke, electronic fuel injection is controlled on start up by temperature sensors, AFM/ pressure sensor and idle control valve and if any are faulty then it can cause bad starting. Quote Link to comment Share on other sites More sharing options...
Guest skans789 Posted November 3, 2008 Share Posted November 3, 2008 ive got a J Spec supra twin turbo, might not be the choke then, its the big black pipe that you have to take off, and spray in to there. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 3, 2008 Share Posted November 3, 2008 ive got a J Spec supra twin turbo, might not be the choke then, its the big black pipe that you have to take off, and spray in to there. Well I'm afraid that doesn't give much of a clue, but i assume you may be referring to the intake pipe to the throttle body, and if you spray carb cleaner in then i suspect it probably a sensor problem, but with you're lack of knowledge, i would be inclined to take it to a garage that knows what there doing with supras. Quote Link to comment Share on other sites More sharing options...
Guest skans789 Posted November 4, 2008 Share Posted November 4, 2008 Yep thats it mate, the Intake pipe to the throttle bodys, i have to spray the cleaner in there, Quote Link to comment Share on other sites More sharing options...
Jake Posted November 4, 2008 Share Posted November 4, 2008 ive got a J Spec supra twin turbo, You said it was a UK Spec before - or is this a different car? Quote Link to comment Share on other sites More sharing options...
Guest skans789 Posted November 4, 2008 Share Posted November 4, 2008 different car mate. Quote Link to comment Share on other sites More sharing options...
