Power Steering Cooler Pipe Size
Wez
  • 2 weeks later...
Bugger, your right, its -8, but pump to reservoir pipe is -12
Are you sure its -12AN, the oem part that connects to the pump has been retained, cut and welded with a -10AN on mine, there is no way you would manage to fit a -12AN on flush, the diameter of a -12AN fitting is bigger than the oem part too
