cowboy bebop Posted July 24, 2008 Share Posted July 24, 2008 Hi guys, Here's a few pics of a 2uzfe motor we're building for a UK member. This UK member is asking for a high compression NA that revs high, and make strong Tq down low. Perfect for the English countryside. By the time we're done with it, we arrive at 4.9L total displacement with a responsive 11:1 compression ratio. Perfect for a great HP NA, even great for a hefty shot of nitrous. On with the pics: Core block and heads: Various motor components going in. The block is part way through being bored now, and next will be shotpeened. After that the honing begins. More pics to come!! Eric Quote Link to comment Share on other sites More sharing options...
AlanM Posted July 24, 2008 Share Posted July 24, 2008 subscribed Any idea of time scales? Is this cost effective relative to the stroker kit/single turbo route? Quote Link to comment Share on other sites More sharing options...
Wez Posted July 24, 2008 Share Posted July 24, 2008 Interesting, subscribed Quote Link to comment Share on other sites More sharing options...
Homer Posted July 24, 2008 Share Posted July 24, 2008 Oooh, this should be a good thread VERY interested to see how this progresses! Quote Link to comment Share on other sites More sharing options...
RedM Posted July 24, 2008 Share Posted July 24, 2008 Oooh, this should be a good thread VERY interested to see how this progresses! Do it. Do it. Quote Link to comment Share on other sites More sharing options...
Alex Posted July 24, 2008 Share Posted July 24, 2008 This will be good Quote Link to comment Share on other sites More sharing options...
Scott Posted July 24, 2008 Share Posted July 24, 2008 Subscribed Quote Link to comment Share on other sites More sharing options...
Scott Posted July 24, 2008 Share Posted July 24, 2008 This will be good Happy 13th Quote Link to comment Share on other sites More sharing options...
Alex Posted July 24, 2008 Share Posted July 24, 2008 Happy 13th That literally took me a minute to work out WTF.... Now back on target. (And thanks!) Quote Link to comment Share on other sites More sharing options...
MarkR Posted July 24, 2008 Share Posted July 24, 2008 I look forward to this. Good pics as always Quote Link to comment Share on other sites More sharing options...
arvind8811 Posted July 24, 2008 Share Posted July 24, 2008 NA power lol Quote Link to comment Share on other sites More sharing options...
cowboy bebop Posted July 24, 2008 Author Share Posted July 24, 2008 subscribed Any idea of time scales? Is this cost effective relative to the stroker kit/single turbo route? With this build being more straight forward than the other builds we've done, we expect this motor to be completed VERY fast. We may have it in the hands of the owner by the end of August, it can go that quickly. We've got the intake manifold in progress now, and it's going to be indentical to mine. Also not pictured but present is the clutch. It's an twin ceramic/metalic clutch that weighs only 19lbs. It holds ~800ft/lbs. This route is indeed cost effect compared to a stroker/single route. Maybe even a little less in cost depending how the motor is built. A motor looking to make ~800Hp/Tq with instant boost WITH turbo kit ballparks at around 11-12K GBP. A high HP NA may run 8-9kGBP. That's with clutch, intake mani, adapter, and an assembled motor in a pallet ready to drop in. Quote Link to comment Share on other sites More sharing options...
jevansio Posted July 24, 2008 Share Posted July 24, 2008 Nice one Eric. What sort of performance is it going to be comparable with, LS2? When you say high revving, how high? Subscribed Quote Link to comment Share on other sites More sharing options...
AndyT Posted July 24, 2008 Share Posted July 24, 2008 Is this Ed's? Quote Link to comment Share on other sites More sharing options...
cowboy bebop Posted July 24, 2008 Author Share Posted July 24, 2008 NA power lol NA power on these motors can go very high. Some 5.65L stroked NA motors with a hardcore cam can run 650HP! A good displacement, 4 cam V8 makes driving fun. Eric Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted July 24, 2008 Share Posted July 24, 2008 lovely stuff lads....good work Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 24, 2008 Share Posted July 24, 2008 That is seriously cool. I love the build pics. Makes singles look a bit weak now doesn't it? Quote Link to comment Share on other sites More sharing options...
cowboy bebop Posted July 24, 2008 Author Share Posted July 24, 2008 Nice one Eric. What sort of performance is it going to be comparable with, LS2? When you say high revving, how high? Subscribed Well, the LS2 does have a bit more displacement, but one this motor we're looking for ~425rwhp. This build while a higher compression is a has a milder more streetable cam. That means the torque will come on sooner and be a joy to drive around the countryside. I've lived in Leeds, and had to drive everyday through the countryside to Menwith Hill, and those roads would be perfect for a responsive, torquey V8. With our standard valve springs, we recommend running up to 8500 for safely staving off valve float. A lot of it depends on the cams though. If the cams are a milder set, there's no need to rev it higher after the tq curve drops off. On a hotter set of cams with massive lift we can order a set of dual valve springs with a heavier seat and nose pressure. I don't want to throw around the 10K rpm number, but I'll say that 9500 range is within reason. Make sure that the rod bolts are custom age 625 though Thanks ! Eric Quote Link to comment Share on other sites More sharing options...
jevansio Posted July 24, 2008 Share Posted July 24, 2008 It's going to sound pretty mental @ 8.5k , very nice Quote Link to comment Share on other sites More sharing options...
AlanM Posted July 24, 2008 Share Posted July 24, 2008 Yep, seems pretty good for money Quote Link to comment Share on other sites More sharing options...
cowboy bebop Posted July 24, 2008 Author Share Posted July 24, 2008 It's going to sound pretty mental @ 8.5k , very nice I've seen Ed Oat's video of him revving to 9300rpm, and it sounds like sweet cream butter Eric Quote Link to comment Share on other sites More sharing options...
Thorin Posted July 24, 2008 Share Posted July 24, 2008 I've lived in Leeds, and had to drive everyday through the countryside to Menwith Hill, and those roads would be perfect for a responsive, torquey V8. Well I never knew that! Where abouts round here did you live? Quote Link to comment Share on other sites More sharing options...
UltraFlynn Posted July 24, 2008 Share Posted July 24, 2008 I just love V8s....... Quote Link to comment Share on other sites More sharing options...
cowboy bebop Posted July 24, 2008 Author Share Posted July 24, 2008 Well I never knew that! Where abouts round here did you live? They had us hooched up at the Park Plaza Leedsfor 6 months back in 2004 . It was a great time, I'd love to get back there. Thanks again! Eric Quote Link to comment Share on other sites More sharing options...
johnny g Posted July 24, 2008 Share Posted July 24, 2008 I worked in Wellington Street then, and stayed in the Novotel by the Station Quote Link to comment Share on other sites More sharing options...
