Group buy on Bosch 044 fuel pump kit
Wez
Hey All,
Would anyone be interested in a group buy for a Bosch 044 fuel pump kit. Ideally we need 10 people.
Price will be between £135 and £155 plus UK delivery.
The kit would include :-
* Bosch Pump #0 580 254 044
* Fuel sock for 044 pump
* -8AN outlet adapter
A kit like this would normally retail at approx £160 +vat +delivery
When I have a number of people interested I will work on a price.
Here is a pic of a similar kit installed on a Supra hanger.
Here is a flow chart showing comparison to a Walbro 255LPH.
Here is a char to show the current draw, @ 5bar its approx 13A
Edited by Wez (see edit history)
How does this compare to JDM/UK/Walbro?
Nice chart adding after I'd said this :p
Can you just pull out the stock/Walbro item and stick this in without any modifications? No wiring/voltage/clever circuitry issues? I'm worried that the Walbro is too near its limits on my 550bhp single.
I'd buy 2 socks if they were handy money, with the union to go onto 044 pumps. Prices??
A word of warning, the stock Toyota connector plug affair on the tank top doesn't like carrying much more than stock pump current, I have seen them melt with the heat when passing a lot of amps :( Obviously not a good place for lots of heat.
:p
It should be just like swapping from stock to a Walbro, I intend to use it with stock lines and drop in injectors.
Current flow chart added to first post.
Once I have an idea on numbers I can get some prices and bundle on two socks for you.
Whats a lot of amps, at 5bar these are drawing approx 13A.
It's a good point, as far as I found the draw should be fine for the 044, but the stock wiring is not capable of handling twin walbro's.. especially after seeing the melted wiring on dudes car.
Hey All,
Typical :p
so whats the limit for these pumps..could 750bhp be supported? or is that too much?
I think its more like 700hp but then the Walbro is supposed to only support 500hp, there are a few cars on here running more than that, mine included.
Are you running your car on a single walbro?
What are these like for noise in cabin?
I have two walbros just now, but I plan on buying the UK spec oem pumps, with the triple hanger, this may be a cheaper option
Currently, yes.
I imagine they will be a little bit louder than a Walbro
3 Denso pumps, crazy, how much HP are you aiming for?
lol...no 2 Denso pumps with the tripple hanger, I wouldnt need the tripple hanger if I bought this, but if I keep the car, the cabin noise might annoy me if the bosch is whiney...the reason I dont really want twin walbros
