Dave Posted March 2, 2008 Share Posted March 2, 2008 one of my springs snapped on the car they were lowered ones anyway got some standard springs cause i wanted to raise the ride height a bit so i could use if for work gotta park in the multi storey . anyway fitted the fronts today and have got a 3.5 inch gap between the tyre and arch lip this cant be right can it .maybe i need the standard shocks as well any advice or help will be helpfull thanks ---dave:( got the rears but havent fitted them yet would this make any difference ??? pics are of the front Link to comment Share on other sites More sharing options...
Pig Posted March 2, 2008 Share Posted March 2, 2008 If thats the front its about right. My UK is crazy high. Link to comment Share on other sites More sharing options...
Sparky Posted March 2, 2008 Share Posted March 2, 2008 Have you driven it since? I find springs take time to compress fully! Link to comment Share on other sites More sharing options...
JamesC Posted March 2, 2008 Share Posted March 2, 2008 It does look high, but my old N/A with stock suspension was high on the front too: Link to comment Share on other sites More sharing options...
Dave Posted March 2, 2008 Author Share Posted March 2, 2008 taken it for a drive and it came down a little photos are after the drive maybe when i put the rears on it will level it out ?? just been reading the manual and it says the shaft on the shock should move freely in and out i couldnt move either of mine they were really stiff maybe thats the prob Link to comment Share on other sites More sharing options...
Dave Posted March 3, 2008 Author Share Posted March 3, 2008 if the shock shafts are siezed would this stop the srpings settling to the correct level Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted March 3, 2008 Share Posted March 3, 2008 if the shock shafts are siezed would this stop the srpings settling to the correct level Yes mate i would say so . Link to comment Share on other sites More sharing options...
dini_the_owl Posted March 3, 2008 Share Posted March 3, 2008 my old stock ones i could push down with my hands,toyota billies on the other hand are much stiffer and you cant push them down. Link to comment Share on other sites More sharing options...
Dave Posted March 4, 2008 Author Share Posted March 4, 2008 i got KYBs all round, its wierd cause there is no bounce in the suspension its rock hard.i though standard springs would have some bounce in them Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 5, 2008 Share Posted March 5, 2008 I take it you have painted the springs red, as stock springs are always originally black? Did you tighten the wishbone bolts with the car sat on the ramp, with the weight on the tyres? If not, and you did it at full droop, it'll raise the car as the bushes are now HEAVILY preloaded, and you will be buying new wishbones next, as it'll 8ugger them in no time at all, if it's not already damaged them. CJ is your friend... Link to comment Share on other sites More sharing options...
Dave Posted March 5, 2008 Author Share Posted March 5, 2008 thanks chris you may have solved the problem its only parked in the drive not using it only went up the road and back 1/2 mile will go and jack it up and loosen the wishbone nuts [yeah i did paint them] i knew something wasnt right i feel such an idiot for not realiseing what ive done its not as if i havent done this job before Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 5, 2008 Share Posted March 5, 2008 You need to tighten them up with the car on it's wheels on the ground, which is all but impossible without a ramp. Link to comment Share on other sites More sharing options...
Dave Posted March 5, 2008 Author Share Posted March 5, 2008 You need to tighten them up with the car on it's wheels on the ground, which is all but impossible without a ramp. how tight should they be what tourqe . this is the intructions in the manual can i do it this way no.1- 3 and 4 1) Install upper control arm bolt with bolt head toward front of vehicle, leaving it loose at this time. Install upper ball joint. Install and tighten upper ball joint nut to specification. See TORQUE SPECIFICATIONS. 2) Install splash shield and windshield washer fluid reservoir (if removed). Install clamp for speed sensor wiring. Install speed sensor, brake caliper, and front wheel. Tighten bolts and wheel lug nuts to specification. 3) Lower vehicle. Bounce vehicle several times to settle suspension. Position floor jack under lower control arm. Raise vehicle. Remove front wheel. 4) Tighten upper control arm bolt to specification with vehicle weight on lower control arm. Install front wheel. Check wheel alignment. See WHEEL ALIGNMENT SPECIFICATIONS & PROCEDURES article in WHEEL ALIGNMENT section. Link to comment Share on other sites More sharing options...
Scooter Posted March 5, 2008 Share Posted March 5, 2008 in the manual it says to "support the lower arm with a jack" and torque bolt to 164NM (121ft-lbs) Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 5, 2008 Share Posted March 5, 2008 Hmm, if you are happy pulling on a spanner to achieve that sort of torque with the car supported like that it'll be fine, suspension pre load wise. Safety wise? I'd probably do it on my own car if I wasn't fortunate enough to have a ramp, but in these litigious times I couldn't be seen to suggest it, of course Link to comment Share on other sites More sharing options...
Dave Posted March 5, 2008 Author Share Posted March 5, 2008 you never said anything chris i followed the manual BTW thanks for your help --dave Link to comment Share on other sites More sharing options...
Dave Posted March 6, 2008 Author Share Posted March 6, 2008 did what you said chris but hasent dropped it by much ,so brought some billies with eibachs gonna fit them Link to comment Share on other sites More sharing options...
