Winter project almost finished.
b_have
Almost done, fitted a Jun clone plenum, which meant relocating the battery to the boot, relocating the ps res,relocating fusebox and fabricating new ic pipework (actually almost 2 feet shorter now it takes a more direct route under the headlight.
Also reworked the head and fitted some 264/264 cams and a new breather system.
  • 2 weeks later...
Last few things completed today, Plumbed in two -10 breathers to a baffled catch can and into the intake with using a slashcut to create vacuum. Fitted a rad fan temp switch into the alloy top hose neck and wired up the relays for the fans.
MOT on Monday, then ready for some mapping :)
Looking good mate!
Where did you get the flexi pipe on the tubby intake from, my mates been looking for some for his evo for ages!?
Hyphahose is Poole.Can't remember the name but its quite flexible and smooth internally.
