Active Spoiler vs MPG
mawby
I reckon that you'd only see an improvement in MPG over very long distances and if you avoid getting your boost on. I expect that Toyota designed it to be pretty slippery.
If one did see an improvement specifically after removing it then you have to apportion some of that to the weight saving.
Further more, I always felt that the car felt wrong at speed with the spoiler up.
I watched an episode of mythbusters where they did a test with a pick up truck with the rear door open and the rear door closed. It was actually more efficient with the door closed as it caused a vortex effect forcing the air over the cab at the back rather than down in to it.
Perhaps the AS does a simliar thing forcing the air over the top of the car more efficiently ?
There we go, my curiosity has been satisfied. :D
I can't say as I'm the lightest person with my right foot though ;)
Long distance motorway runs (~250 miles) used about the same fuel before and after I removed it.
How do you mean by the car "felt wrong"? I haven't noticed any difference really, but I tend not to chuck the Supra around too much at speeds where the spoiler is down.
Doesn't it direct airflow up into the engine bay more efficiently than without it? So if you're hooning it around on autobahns at 150+ all day, it helps keep things a little cooler than they might be. I always figured that was why it came as standard on UK cars, same as the bonnet scoop and rear diff cooler.
According to the official brochure "Front and rear spoliers counter lift, using the air-flow at high speeds to create downforce. The front spoiler deloys automatically at speeds over 50 mph"
As for the UK bonnet scoop, according to the same document it "...directs cooling air through the exhaust manifold to improve fuel consumption at high speeds". I think I'll start a new thread to discuss that one though. :)
Well that would explain why mine used to feel odd at speed with the spoiler up. However, my spoiler only came down at 60 mph which I thought was standard for all of them. I take it that it's only JDM cars that are set to 60?
hehe true, but I meant that I'd see a more noticable difference in consumption on boost with the spoiler down, rather than on boost with it up if that makes sense?
Could you guestimate how much of a difference? (e.g. An extra 10, 20, 100 miles out of tank of fuel?)
I can't see how? Doesn't the boost drop off when you are at a steady speed? On long m-way drives I always found that the boost (or seeing that I didn't have a boost gauge, the turbo sounds) dropped away only returning if going uphill or me putting my foot down.
Is a stock TT on boost at 90mph even if you are driving steadily?
