mapping advice
Guest daz 6576
Guest daz 6576
once i have completed my single upgrade am i going to be able to drive the car at all because it would not have been mapped.
what happens then
standard ecu on a tt auto j-spec
it also has a fcd and a sld
If you are fitting a single turbo, you will need at least a mappable piggyback ECU, ideally a full standalone ECU. You will also need to upgrade the fueling, etc. etc.
What kit are you fitting and what is the full spec of your car?
Guest daz 6576
the turbo is a hks t04r
car has got a fmic, koyo radiator, sld,fcd,full race exhaust system 3 inch with decat, iridium plugs, electronic boost controller,
im starting my install soon so still buying parts at the mo
up to now i got a manifold made out of 321 stainless with a 50mm flange, 50mm external wastegate,turbo,im getting the injectors soon and a fuel pump
What ECU are you going for? What is your power aim? Just if you are keeping the autobox you are going to be stuck around the 400-450rwhp as i really would not want to risk anymore.
Just think back really matey from my own experience i bought a EMU + PE650cc injectors on a standard box but i quickly found out that i was perhaps a tad short sighted as the setup would not meet my power requirements/drivability.
So it would have been much better(cheaper) if i had saved a bit more and bought what i have gone for now in the first place!
Also have you been out in a auto single setup? I wish i had been out in a few more before i did mine!
I can not recommend Ryan G connected to your car via a laptop and AEM enough! Its totally change my car!
