some little messy snaps of the car
jazz1
I quite like the do-luck wings. Maybe its the light but it appears the panel gap/panel flow to the bonnet is really bad... I hope it's not after all the work thats been put in but it doesn't looks too good from the pics. Can you get a better pic?
Oh and whats with the masked eye lids. Fit those and I'll ban you within the hour :D
lol guess i need to lower the car to make it look better:p
That won't help one bit, it'll still end up looking like one of those chaved up escorts.
Stick on headlight sh*t like this is the ultimate in chavness. It is wrong beyond belief
Yes, I know some of the tuners promote these, but then they operate a business, the products they offer are not always going to be tasteful, just marketable ;)
Crystal clear UK lights would look good with that kit - good suggestion supragal.
As far as do-luck wing and eyebrows - you will know when you see them fitted if you like it or not... if you like what you see, keep them. It's your car and while you might care what other people think, what you think is the most important thing.
bonnet was up when i took those so it wasnt fully down, the do luck wings at first had a massive gap from the left to the bonnet but its all sorted and all perfect my dad fixed that little problem:)
Do you mind me asking you how you managed to fix the problem with the gap between the wings and bonnet ? Just that mine has the same problem, although my wings are not do-luck...
drill a hole where the wings attacth to the top part of the nuts bigger towards youself, then push the wings towards the bonnet and tighten the bolts, my gap was nearly an inch away but its all sorted now
Thanks for that, I'll give that a try,...
