T2 MSW Posted September 21, 2007 Share Posted September 21, 2007 In the process of changing my rear wishbone bushes. Got the lower ones out no problem but the uppers are a PITA. Can anyone recommend from experience how to get them out, below is a list of what I have tried. Bearing press - can not get enough preasure Heated the wishbone in the hope it would expand slightly Vice and large mallet Drilled the bush out - broke crist knows how many drill bits. Today I have take the bush to a MOT station and they have tried pressing it out but they are having the same issues I am, the inside of the bush is just moving (on its pivot) which means it bends the bolt. Cant get a flat service to get a big enough plate on it and therefore enough force behind it. Is the only option left to get a hacksaw on the internal shield and cut it to bits? once cut in half will it come out?? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 21, 2007 Share Posted September 21, 2007 Now you know why it's a job I politely decline They aren't a normal rubber bush, so you can't burn them out and slit the outer shell, with a hacksaw. They are spherical bearings. I take it you are replacing them with some plastic deformable things, having been told they take the compliance out, but actually you will be adding it, and to somewhere you don't want it. One of the makers of these things is asking for design engineers in the back of Autosport magazine. Quite what qualifications you need to design a spongy plastic bush to replace a spherical bearing I don't know...They obviously have good marketing people though Quote Link to comment Share on other sites More sharing options...
Guest Killer Heels Posted September 21, 2007 Share Posted September 21, 2007 Cheers for the input Chris, So am I best leaving these bushes and just replacing the lower arm and sway bar ones?? Quote Link to comment Share on other sites More sharing options...
Ian Ian Posted September 21, 2007 Share Posted September 21, 2007 Cheers for the input Chris, So am I best leaving these bushes and just replacing the lower arm and sway bar ones?? piggin eck you sound like Mike there Kate !! Cheers -Ian- Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 21, 2007 Author Share Posted September 21, 2007 lol, bloody pain in the arse is logged on my laptop as her! look well stupid now Quote Link to comment Share on other sites More sharing options...
Havard Posted September 21, 2007 Share Posted September 21, 2007 lol, bloody pain in the arse is logged on my laptop as her! look well stupid now No shit!! I was surprised how much Kate knew about suspension..... H. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 21, 2007 Author Share Posted September 21, 2007 She's a jack of all trades! lol This mini project is starting to turn into a PITA. The lower arms are a peice of piss but the upper ones - Put it this way, Chris is right when he says you can't saw them out with a hack saw! Quote Link to comment Share on other sites More sharing options...
M4RK RZ Posted September 21, 2007 Share Posted September 21, 2007 dude - buy a new one from mr T (trust me on this one) Quote Link to comment Share on other sites More sharing options...
Suprash Posted September 22, 2007 Share Posted September 22, 2007 I have just bought both upper and lower arms to replace mine........bought one lower from Toyota UK, cost a little over £200 if memory serves me correct, then bought the other lower and two upper through Nic for just over £400 although I did have an O2 sensor in with that as well, but good prices through Nic as all 4 through Toyota UK would have been expensive...... Contact Nic mate, might have to wait 5 weeks though, so not sure if your Supe could be off the road till then...... Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 22, 2007 Author Share Posted September 22, 2007 Only reason I am replacing the Bushis and not the whole are is beacuse I already have the rear Bush kit. Way well end up getting the uppers rom Nic in the end. Quote Link to comment Share on other sites More sharing options...
M4RK RZ Posted September 22, 2007 Share Posted September 22, 2007 I did a massive search for this part mate - you cant get it. The bush has a fused metal insert and the bush kits you buy are only PPE. I even called australia ( for everyones reference thats where all the branded high end bush kits come from I found out! all made by 1 place) I did get an Email saying they were working on on but was in testing. Also give a place called TRAC ART a ring they were very helpful and were also working on it at the time. to be honest your going to have to but an arm gutting I know ! Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 22, 2007 Author Share Posted September 22, 2007 Cheers for the Info Quote Link to comment Share on other sites More sharing options...
hadyn Posted September 22, 2007 Share Posted September 22, 2007 So is changing the rear wishbones, arms and other suspension linkages a complete nightmare on the mkiv??? Quote Link to comment Share on other sites More sharing options...
M4RK RZ Posted September 22, 2007 Share Posted September 22, 2007 So is changing the rear wishbones, arms and other suspension linkages a complete nightmare on the mkiv??? Nope - just the one hes on about rear upper Quote Link to comment Share on other sites More sharing options...
hadyn Posted September 22, 2007 Share Posted September 22, 2007 So your average mechanic wont be able to remove the rear upper wishbone?? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 22, 2007 Share Posted September 22, 2007 Cheers for the input Chris, So am I best leaving these bushes and just replacing the lower arm and sway bar ones?? Put a pair of new top arms on, and a pair of new rear lower toe links. Quote Link to comment Share on other sites More sharing options...
M4RK RZ Posted September 22, 2007 Share Posted September 22, 2007 So your average mechanic wont be able to remove the rear upper wishbone?? You have to drop the rear sub frame to get the tools in to do the job. They can do it Quote Link to comment Share on other sites More sharing options...
Jspec Germany Posted September 22, 2007 Share Posted September 22, 2007 Put a pair of new top arms on, and a pair of new rear lower toe links. Chris - which is the lower toe link? Is that the short arm or the long one? My rear suspension is worn and I have new Teins going in (without the top mounts because a lot of people say they're too loud and there's no benefit). I have the rear lower arms (short) ready to go in on your advisement. Hopefully this fixes the shifty side to side yawing of the rearend. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 22, 2007 Author Share Posted September 22, 2007 Put a pair of new top arms on, and a pair of new rear lower toe links. Cheers Chris. Will be buying new upper arms and getting someone else to install them. Ive replaced the bushes in the lower arm from my kit and will be doing the same with the sway bars. But to answer peoples questions about is it difficult on a MKIV - darn right it is. 3 hrs today to do just the lower arms due to rusted bolts etc, The role bar links were the worst. Chris how difficult are the sway bars to get undone? And are they the same type of bushes as the lower arm or the ones in the upper wishbone? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 23, 2007 Share Posted September 23, 2007 You have to drop the rear sub frame to get the tools in to do the job. They can do it I have never had to do this, although without a special tool the nuts are hard to reach. Quote Link to comment Share on other sites More sharing options...
Jspec Germany Posted September 27, 2007 Share Posted September 27, 2007 Ok, I'm off to price the upper arms. Are these the rear lower toe links you're talking about? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 27, 2007 Share Posted September 27, 2007 Ok, I'm off to price the upper arms. Are these the rear lower toe links you're talking about? Yes, those are the ones, the ball joints wear, but you need significant forces on the hub for it to show when looking for it. Nic in HK does a great price on the suspension parts. Quote Link to comment Share on other sites More sharing options...
Jspec Germany Posted October 6, 2007 Share Posted October 6, 2007 Ok, thanks Chris. I'll drop Nic a PM for a quote on the top arms. I'm putting in Teins really soon, so might as well do it all at one time. Quote Link to comment Share on other sites More sharing options...
