DamanC Posted June 30, 2007 Share Posted June 30, 2007 Ive started to replace my old and brittle Vacuum hose's. I brought a selection of 3mm, 6mm and 9mm internal sized hose's @ japshow and have pulled the existing ones off and they seem to not be 3,6 or 9 as they have shrunk/expanded over the years. Does anyone have a list or ideally i diagram of what size needs to replace what? Cheers Link to comment Share on other sites More sharing options...
uzthedentist Posted June 30, 2007 Share Posted June 30, 2007 4s 5s and 6s will do the trick mate and one is 3mm Link to comment Share on other sites More sharing options...
DamanC Posted July 1, 2007 Author Share Posted July 1, 2007 Thanks fella, so my 9's are useless then? Link to comment Share on other sites More sharing options...
DamanC Posted July 2, 2007 Author Share Posted July 2, 2007 Bump Link to comment Share on other sites More sharing options...
DamanC Posted July 3, 2007 Author Share Posted July 3, 2007 Doooowup! Link to comment Share on other sites More sharing options...
uzthedentist Posted July 3, 2007 Share Posted July 3, 2007 sorry mate just realised the post 9mm vac hoses are bloody useless, and any apllication that uses a 9mm hose, i wouldnt trust a vac hose on it, better to use reinforced nylon Link to comment Share on other sites More sharing options...
DamanC Posted July 3, 2007 Author Share Posted July 3, 2007 Perfect picture, thanks Ive already started replacing the 5mm and 4mm hose's (found labbled just off left to the middle) with both 6mm.........time to put the stock ones back on? Link to comment Share on other sites More sharing options...
uzthedentist Posted July 3, 2007 Share Posted July 3, 2007 6mm is a bit big really but i dunno wat effect it would have, apart from being loose Link to comment Share on other sites More sharing options...
